2025+ RAM 1500 RHO / Rebel 23in Light Bar - Slim
MandRautomotive
Supporting Vendor 🛒
2025 RAM RHO
2000 Dodge Viper
Fits 2025+ RAM 1500 RHO and Rebel models only
This is a new lightbar size for us and requires about 6 weeks for production. You can place your orders now. Shipping around 6/15/2025- 6/31/2025.
  • Curved light bar - Slim
  • Fits in between the grille and bumper
  • Slim and sleek, built in look
  • Metal bracket is powder coated black
  • Must remove grille, but don't need to remove the bumper
  • No cutting or drilling required. The kit is a complete bolt on using factory openings and hardware
  • Doesn't interfere with radiator air flow
  • Theoretical max power 100watts
  • Actual power 53watts
  • Main White light is 2.42amps at 12v
  • Backlight Amber is 0.27amps at 12v
  • Theoretical max luminous flux 11,700 lm
  • Measured luminous flux (without lens) 6,720 lm
  • Measured luminous flux (with lens) 5,004 lm
  • LEDs type: luminus SST-20 Ra70
  • Temperature: 6000k
  • LEDs number: 20pcs
Choose your light bar color:​
1) White LED -- bright and powerful. It will definitely provide you with enough light needed for all of your adventures. However, these are only for off-roading and can’t be used on the regular road. They will blind the in-coming traffic and also violates road safety.
2) Amber LED -- used in poor driving conditions such as dust, fog, snow and rain. It reflects through air particles much less than the white light. Therefore, making it ideal for poor driving conditions. For off road use only.
3) dual function: main White LED light with Amber DRL backglow -- the white LED light is same as described above, but the amber DRL “daytime running lights” acts purely for aesthetics. Since it doesn’t give out much light, you can use this amber DRL feature on regular roads, it doesn't blind in-coming traffic.
Made a step by step installation video to show how easy it is to install the product
Quick Summary of the video
Pro light bars are spot beam pattern and can throw light further down the distance when compared with slim. Pro version provides more lumens straight ahead of the vehicle. Slim light bars are combo beam pattern so they throw light at a wider angle providing more peripheral angle just not as intense as the pro
Hey guys just a heads up the factory said 3-4 weeks untill shipping time
