Active Lane Management Limited Blind Spot Alert Unavailable
Sgod17
Sggsag1997#
RHO
Have anyone ran in to blind spot unavailable issues, wife turned it on and it popped out instantly. Some people on fb said it only popped out on their passenger side mines is on both.
Is this a sign that my battery about to go ?
Currently sitting at 13.6 Idle when driving 13.9 to 14.5 . Thanks ahead
I had that issue. It happened a few times since I got the truck. When I took it in for an oil change I brought it up and this is what they found.
Thank you so much man I’ll take it in I was lucky to find a close open appointment but will take it in to see if they can diagnose that same issue
I wasnt sure if they would find anything because it was fine when I brought the truck in. I took screen shots from the ram app of the messages I got and showed it to the tech and he said he had to do some digging to find the faults. Also the part they replaced I was told controlled a lot of functions so we’ll see, knock on wood its fixed. Part came in two business days and it took them just under an hour so get it replaced.
