Alcon BBK Available for 2025+ RHO
Nick797
Supporting Vendor 🛒
Feasterville, PA
2025 Ram RHO, 2022 Ram 2500
We have confirmed that these kits work on the RHO!
You will need a scan tool to bleed the brakes at minimum. We tried pinching the line off and doing a quick bleed as the actual install of these was only about 10 minutes per side.
Have put about 500 miles on the truck with this kit so far, and its been great, we did not upgrade anything in the rear but pedal feels great, bite feels great, very confident in stopping/slowing down, as far as before & after we don't have at TON of input as the truck only had 150 miles on it when we did the install.
This is absolutely not needed for 90 percent of customers, BUT if you are looking for a 6 piston kit that doesn't require upgrading the wheels to a 20 inch wheel or cutting/grinding anything. This is a direct swap.
These kits do retail for a pretty penny $3450, but we can do the 3 kits we have in stock for $2899.
Check the kit out on our site below:
Alcon 6 Piston Brake Kit
