- Nov 10, 2023
- 282
- Media
- 2
- 140
- Location
- Palm City, Florida
- Ram TRX
- Current Ride #2
- S197 Mustang
RAM RHO owners — one of the most common questions we're getting right now is:
"What are the best power running boards for the 2025-2026 RAM RHO?"
For most owners, the answer comes down to two options from AMP Research:
AMP Research PowerStep (76 Series) AMP Research PowerStep XL (77 Series)
The good news? Both are currently in stock.
When you open the door, the step automatically deploys. Close the door and it retracts neatly under the rocker panel, preserving the clean look of the truck.
✓ Clean factory-style appearance
✓ Excellent ground clearance when retracted
✓ No permanent step hanging below the truck
✓ Plug-and-play vehicle-specific fitment for the RAM RHO
AMP Research PowerStep 76 Series for 2025-2026 RAM RHO:
https://justboltons.com/amp-researc...025-ram-1500-2025-ram-rho-gas-only-76364-01a/
The XL version provides approximately 4 inches of additional drop compared to the standard PowerStep.
✓ Easier entry for lifted or leveled trucks
✓ Great for families and daily drivers
✓ Automatic deploy and retract operation
✓ Same AMP Research reliability and functionality
AMP Research PowerStep XL 77 Series for 2025-2026 RAM RHO:
https://justboltons.com/amp-researc...025-ram-1500-2025-ram-rho-gas-only-77364-01a/
If you're running larger tires, planning suspension modifications, or simply want the easiest possible entry into the truck, the 77 Series PowerStep XL is often the better choice.
Both systems are vehicle-specific and designed specifically for the 2025-2026 RAM RHO, making them two of the best running board upgrades currently available for the platform.
Best Running Boards for the 2025-2026 RAM RHO — AMP Research PowerSteps & PowerStep XL
https://justboltons.com/blog/best-r...powersteps-and-powerstep-xl-are-in-stock-now/
1-844-526-2658 | [email protected]
Live Chat Available on Site
Financing Available Through Klarna, AfterPay, PayPal Credit & Affirm
Both the AMP Research PowerStep 76 Series and PowerStep XL 77 Series are currently in stock for the 2025-2026 RAM RHO.
AMP Research PowerStep (76 Series) for RAM RHO
The standard AMP PowerStep is the most popular powered running board available for the RAM platform.When you open the door, the step automatically deploys. Close the door and it retracts neatly under the rocker panel, preserving the clean look of the truck.
Benefits of the AMP PowerStep 76 Series
✓ Automatic deploy and retract operation✓ Clean factory-style appearance
AMP Research PowerStep XL (77 Series) for RAM RHO
For RHO owners running larger tires, added ride height, or anyone wanting easier entry and exit, the PowerStep XL is worth considering.The XL version provides approximately 4 inches of additional drop compared to the standard PowerStep.
Benefits of the AMP PowerStep XL 77 Series
✓ Approximately 4" lower step position✓ Easier entry for lifted or leveled trucks
Which AMP PowerStep Is Best for the RAM RHO?
If you're keeping the truck mostly stock height, the 76 Series PowerStep is usually the go-to option.If you're running larger tires, planning suspension modifications, or simply want the easiest possible entry into the truck, the 77 Series PowerStep XL is often the better choice.
More Information: Best Running Boards for the RAM RHO
We recently put together a complete breakdown covering both systems, installation considerations, and which option may fit your truck best:Best Running Boards for the 2025-2026 RAM RHO — AMP Research PowerSteps & PowerStep XL
Have Questions?
Whether you're deciding between the AMP PowerStep vs PowerStep XL, need help with fitment, or want pricing information, feel free to reach out.Both the AMP Research PowerStep 76 Series and PowerStep XL 77 Series are currently in stock for the 2025-2026 RAM RHO.
