Base vs Level 1 cargo light - incandescent lightbulb 🤦🏻‍♂️
RH0
Anyone with the base model (level 0) notice you have an incandescent cargo/bed light? Ridiculous incandescent is still being used.
First photo is base second level 1
Anyone with the base model (level 0) notice you have an incandescent cargo/bed light? Another difference from level one I just noticed. 🤷🏻‍♂️
Yeah I noticed it right away on build sheet breakdown. Also probably noticed so quick because I had a ram once without led and hated it. At the time I think it was only about $300 replacement. The only problem I had was it started leaking afterwards and my headliner was constantly wet. Dealer wouldn't cover issue because not original. Basically it took many car washes to get it straightened out. If you go that route make sure to check your headliner by touch because you can't tell on black and will just mold inside there.
You can also do $20 led bulbs there and at least it will look nicer when on.
