After reading multiple threads about our battery concerns, this appears to be a hot topic.
Has anyone swapped the stock batteries for these? If so, what is your experience?
To provide some context and a bit of a repeat of what I have posted in a previous thread:
"I have also been tracking my battery voltage. When it is above 90 degrees Fahrenheit it starts out around 14.1 volts. However, it then fluctuates when driving between 14.1 and 13.5. On a 100-degree day, it went down to 12.9, but fluctuating back up to 13.5. To my spouse it is the daily battery voltage report.
I had a dealer check the system and perform a load test on the batteries, and they advised there was no issue with them. However, when I took it in, it was a cooler day. They advised if I am not getting a warning light, the batteries should be okay....
I also asked their thoughts on upgrading the battery to something non-Mopar, and they did not recommend it. They thought it could impact the electrical system, going with a battery with higher cranking amps. This did not sound right to me."
