so looking online, this is what i found, can someone in the US confirm. Is the black plug cord on the left what I am looking for things to fit in the RHOs sockets?
TYPE B
This class I plug is designated as American standard NEMA 5-15. It has two flat 1.5 mm thick blades, spaced 12.7 mm apart, measuring 15.9 - 18.3 mm in length and 6.3 mm in width. It also has a 4.8 mm diameter round or U-shaped earth pin, which is 3.2 mm longer than the two flat blades, so the device is grounded before the power is connected. The centre-to-centre distance between the grounding pin and the middle of the imaginary line connecting the two power blades is 11.9 mm. Or, simply put: the earth pin is offset by 11.9 mm. The plug is rated at 15 amps.
