Chemical Guys Bare Bones Undrcarriage Spray
RADA
Apple Valley, CA
USAF
2025 Forged Blue Metallic L1 RHO
Bare Bones
I've been trying to save a few dollars (a deep detail can easily cost $100- $120+Plus Tip, here in Southern Expensifornia), by letting the hand wash place handle the big cleaning, while I focus on the interior, wheel wells, engine bay, undercarriage, and trim.
I tried a bottle of Chemical Guys Bare Bones Undercarriage Spray and was very impressed with the results.
I've applied it 2x, as of Saturday, May 24th.
Bare Bones is a heavy, oily protectant that leaves a thick film to protect the vehicle's underside from street grime.
It gives the undercarriage a shiny, almost new look.
I bet this would be great for our cold-weather RHO family members to reduce winter deicing grime.
Steps Taken::
Cleaned the undercarriage with a power washer and some sort of brush or pad.
If you do this right, you can probably get 3 or 4 post-wash resprays of the Bare Bones before you need to scrub under there again. Of course, this depends on the climate in which you live. It's dry as a dead camel's hump here 80% of the year, so your results might be different.
Sprayed the Bare Bones on everything, wiped down the fender liners, and left it alone everywhere else.
I wanted to post some pictures, but the springtime desert winds have been crazy for the last week, so the truck gets re-dirtied very quickly.
If you're a vehicle clean-freak like me, you'll probably like Bare Bones...
Awesome! I'll check it out! Winters in Ohio wreak havoc on undercarriages!!
I was considering having the underbody ceramic coated. Just kidding :ROFLMAO:
**The cleaner you get the truck's undercarriage before applying, the better results you'll get.
Bare Bones
Steps Taken::
Did you wait for everything to dry after cleaning before you applied it?
I'd label it "mostly dry"... 90 to 95% dry...
There was a bit of water in a few places...
I wiped up any drips under the wheel wells, but ignored the deep undercarriage parts.
It looked a little milky at first, but dries pretty clear.
From more than three feet away you can't see it, and it is the undercarriage, so I wasn't going for a car meet clean...
Every video I watched said the better job cleaning you do, the better it looks, and the easier the cleaning will be the next time around.
Pictures from this morning. Bare Bones applied on Saturday, May 24.
CAVEATE:
I live in a desert climate, where it hasn't rained significantly in over a month (April 25 rainfall total: 0.04"), so your results might be different.
