Cluster smudged on back how to remove and clean
Mpjhockey27
Minnesota
2014 Ram Sport White
When the light hits right my cluster is smudged in many places about 50% of it. I cleaned it and is definitely on the backside from the factory. Is there anyway to remove it easy clean it and put it back together? Kinda a picky thing but during the day I can always see it. Hate to start ripping apart a brand new truck but anyone know how to remove the screen easy behind the steering wheel and put it back together?
I’d let the dealer handle that. You could take it apart and find out it’s scratched rather than smudged and then have to explain to the dealer you didn’t do it. No thanks.
I wouldn’t be able to drive the truck without seeing that. 👎
Let me look at a cluster and see if the lens is removed easy. Cluster removal itself is fairly easy.
Lens doesnt look easily removable. Maybe with some heat it could be but not sure i would try it. Its sealed pretty good. I cracked a lens barely prying on it and used a little heat. Again, with some heat and a lot of patience it could be done maybe.
