Factory Bedside Decal Measurements?
eltaco
Kansas
Army
2020 Ram 1500 Laramie
If you have factory RHO bedside decals on your truck, would you be able to do me a favor and get some measurements on their locations? I had some installed last week and my installer tilted mine just a bit. They offered to redo them, which is awesome, but in fairness I should probably give them some clear measurements to go off of for placement.
If you could measure front and back of the decal with a string from the black bed edge, and also back of the decal to the tail light, those should do the trick!
Thanks!
I'll be tackling this job hopefully tomorrow after work. There's a post floating somewhere around here with a few dimensions
Thanks!
This doesn't give you the tail light measurements you asked for, but this may be helpful if you haven't seen this.
I saw this one, but these measurements aren’t very precise. I’m not sure if they’re accurate or not, and this isn’t a factory decal either.
Thanks!
It's supposed to follow body line so yes there's a slight tilt to them
The OEM decal backing acts as a templet so it can be lined up easier. I will try and get measurements from a truck here on the lot this evening.
From what I’ve seen, it actually doesn’t follow the body line from the factory. That body line is what my installer aligned to, and mine look tilted from the side. Factory images I’ve seen show a larger gap from body line to decal in the front, and smaller gap in the back.
This is exactly the way the oem decal templet ends up placing it. If the truck is leveled, the decal will be end up being tilted.
these pics were taken off my truck, passenger side. these are oem decals, but didn't come on my truck. I have my BodyShop install them. Hope these help.
