No. This won't. It's up to Ram to fix. Edge to edge just means whatever size your AA is. Unfortunately the ball is still in Rams court
This limitation is not on RAM, this has always been a restriction set by Google. With this update, Google is finally lifting these restrictions and RAM owners will soon be able to get Google Maps on their entire 14.5" screen with Android Auto.
It should require nothing further from RAM once Google rolls out this new update.
- The limitation was on Google’s side, not RAM’s.
- Once Google rolls out the new Android Auto version, your truck should automatically support full‑screen Maps.
- RAM does not need to patch Uconnect to enable it.
Your truck already has the hardware and UI container to support full‑screen projection — Google just wasn’t allowing it.
Before this announcement, this is how it worked.
With Apple CarPlay, you can get Google Maps full screen on our RAM 14.5" screen, but not with Android Auto. Apple allows OEM's to stretch CarPlay to any aspect ratio, fill any size display, render UI elements dynamically, and use portrait, landscape, or ultra-wide layouts. Apple designed CarPlay to be resolution-agnostic and adapt to whatever screen the automaker installs.
Google on the other hand, imposes strict constraints on Android Auto. AA only supports certain aspect ratios.
Google limits projection to a maximum width-to-height ratio that the RAM 14.5" portrait screen exceeds; it's too tall and too narrow for Google's approved layouts. If the screen is outside Google’s supported ratios, Android Auto is forced into a “letterboxed” or centered” mode.
Google forbids OEMs from modifying or stretching the UI. RAM cannot stretch Google Maps, remove side gutters, override Android Auto’s aspect ratio rules, or force full‑screen mode. Google locks down the UI to maintain consistency and safety across all vehicles.
Google Maps inside Android Auto is not allowed to run in custom OEM containers. Apple allows OEMs to embed CarPlay in flexible UI frames.
Google does not. Android Auto must run inside a fixed projection window, and RAM cannot change its dimensions.
