All RHO owners…get that rear differential fluid changed! Max miles would be 5000. 2500 miles is probably not too early.
Changed mined yesterday at 5082 miles & it glopped out of the drain hole like chunky maple syrup. Loaded with metal shavings (see photo). The new fluid is nearly clear…the old stuff looked like liquid graphite & smelled horrible. Even found a few chunks of cast iron (biggest was 1/4 pea size), likely left over from the axle housing manufacturing process.
It’s an easy job…easier than an oil change, since there is no filter. You’ll need 3 qts of 75W-140 synthetic ($20/qt for Mopar brand)…but you’ll only use 2 1/4 qt, unless you drip a little like I did. Drain plug is 1/4” drive, fill plug 3/8”. No plug sealant needed…the drain plug has a sealing washer & fill plug fits nice & snug on the rear cover.
Pro-tip: Make sure your fill plug is removed (not just loosened) while draining. It flows 3x better!
