Interior buzz/hum noise
Rebel2RHO
2019 Ram Rebel
Does anyone else have a very subtle and low buzz/hum sound inside when no radio is playing? Trying to figure out if that’s just how the electronics sound or something else
massaging seat
Terrible video due to being dark outside, but I noticed mine making this noise about 30 minutes after I parked it. This is on the driver side front wheel area, but it can be heard from the passenger side as well. Sounds like a fan still running.
  • IMG_6765.MOV
    6.3 MB
I have a noise coming from that same area. Dealer is ordering a new headlight to swap for failing ballast under warranty. I had lights turned off and still thought there was a very subtle hum inside the cab… will see if that’s still there when light is swapped. Other then that RHO has been solid
No sense ignoring it while under warranty. I can’t imagine what a new headlight is going to cost later on down the road!
I also have this humming sound I will check the ballast as well
They have cooling fans also you might be hearing.
I am pretty sure they have pumps run oil to the turbos when the car is off to cool the turbos and help prolong their life. i hear this on the driver side front wheel. sometimes it lasts for about 5-10 minutes but always shuts off.
Just had my driver side headlight swapped due to a buzzing sound. The tech said it coming from the auto level system on headlight
glad you got it sorted out.
I was just thinking about this the other night. With the overall low sales volume of RHO to this point, I wonder how many components are specific only to the RHO trim. For example, is that headlight a standard 1500 headlight shared with some other trims, or specific to RHO? I have to imagine low volume parts are going to end up costing a pretty penny for replacements down the road.
