J&L Oil Separators 10% Off Until July 11th
Nick797
Supporting Vendor 🛒
Feasterville, PA
2025 Ram RHO, 2022 Ram 2500
No coupon code needed! Just add to cart and see the 10% off.
How does it work?
During the process of venting crankcase pressure back through your intake track, large amounts of oil, in the form of vapors, can accumulate in your intake tube, intake manifold runners and even dilute your gas, lowering its octane level. This happens on all engines and is even worse with forced inducted vehicles (supercharged and turbocharged) as crankcase pressures are increased. To combat this, we have developed an oil separator of our own design. Milled from solid billet aluminum this is a rock-solid piece. It has a knurled tank base for easy removal to drain the spent oil and an O-ring seal to prevent any leaks.
Filtering consists of a fine mesh stainless steel filter that traps fine oil vapors and releases them once heavy enough to fall. By the time the oil gets through the filter, it's too heavy to be passed on into the intake. The tank holds 3 oz of fluid, while that may not sound like a lot, you shouldn’t see that much oil in your PCV system. Check the oil separator after 1000 miles of driving. Most applications can make it 2500-3500 before filling the unit but every vehicle is different!
WHY J&L?
Our Oil Separators are easy install, service and flat out work! Many use OEM hoses or come complete with all hoses, custom brackets and hardware for an OEM look. Retain stock hose if you ever return to stock.
For those of you that have installed these I'm hoping to get some feedback. What results are you seeing or how much oil is being caught between your checks of the cannister? How often are you checking it? Is there a before and after installation difference in engine performance (or is it too soon to tell)? Have any of you received comments from your dealers about this being installed? Thanks in advance.
My factory line had a decent tracing of oil in it already. I have about 2000 Miles on my truck now and getting ready to change the oil. CC has only been on for about 1000 of those miles, I will check & report back this week!
Thanks and looking forward to the updates.
