Looking For Ram Bar
RAM-Ranch-MT
Montana
2025 RAM RHO
Ram 2500 Cummins on 26x16
As title says looking for a Ram Bar for TRX/RHO. Any condition as i can have it powder coated easily and may modify. Im in Bozeman, Montana so optimally close bye but I'm pretty sure they can be broken down and shipped ups. I like the look and with limited lighting available for RHO i plan to load it up with some LP6 or LP9 lights. I have already checked local marketplace and nearest ones are in Utah. Looking to grab a take off or used and not pay $2k for oem Mopar. I did find a identical knockoff for $400 on aliexpress but would obviously rather go oem than china for roughly the same price. I also do not like how far it sits above the cab so will likely modify it to be flush with the roof and just lights stick up. Hopefully scrape up some parking garage roofs :ROFLMAO:
Thanks Fellas!
You’ll probably have a hard time chopping down a Rambar. The only part that’s even close to vertical is near the base, and chopping it there would necessitate modifying the slotted panel as well.
Cutting it anywhere else would require reshaping the bars so they all fit together again.
Anyways, it probably isn’t worth all the trouble. It only adds 3/4” to your total height above the shark fin.
You could follow in this guy’s footsteps and modify an Armordillo chase rack.
Thanks for the heads up and pictures! Probably not worth the hassle to modify. I'll likely just leave it as is. I was mainly thinking if I got one with some beat powder, i would remake the corner bent two pieces to drop it down a touch then have it re-coated. Back in the day I was a fabricator at a top tier offroad and custom shop, this would be an easy project for me. But not worth the hassle like i said. Thanks fellas. I'm not really worried about height as I may even throw the 9" lights on there
