No power on AUX wires
acraft
RHO
Hello, I need some help with AUX switches. Truck does not have power on AUX wires, I checked with the volt meter. Light on the switch comes on if pressed but no power on the wire. Does anyone have any ideas what I should check next?
Thanks
Think you have to assign them in the setting's how you want them to function. I thought I saw it in there, don’t quote me if it’s a wild goose chase.
I agree I had a ram with those switches and you went into settings and you can tell each switch what you want it to do.
I have two switches taken up for ditch lights. 1st for full power and 2nd for daytime amber lights. Didn't have to mess in settings for them to work but do remember previously when going through all the settings there is option for aux switches but I didn't have to touch it. My rear lights are just wired to tow connector since didn't want them to function on aux since switches are limited.
You can easily volt test them and if not I would probably start at the fuse.
Well I found the problem, aux pdc is not connected to the main pdc
Well, that'll do it!
