Panel Alignment
lasstss
Maryland
2025 RHO
Solstice coupe
Only had mine a few days now. All seems good but i noticed that the hood alignment to the fenders is not very good. I'm going to make an appointment to get it sorted out.
If it is just a bit low or high on the front corners you can adjust it yourself in seconds. On the front radiator support there are adjusters on the left and right that spin up and down.
Thanks. I know about of all of that. When i lift the stops, the hood wont close. Then I have to adjust the striker etc. Good job for the dealer body shop.
TRXs were also known for the not-so-stellar hood alignments. Some even found out it wasn't the hood misaligned, but the front fenders weren't well aligned. Some were able to fix that by loosening fasteners, pushing/aligning, then tightening back down.
