RAM RHO Behind the grill auxiliary light kit 👌
DBallz
SLC
2025 RHO
This is a pre-order and as such has a discounted price of:
Tank $399.99
Mounts $179.99
RAM TRX / RHO 64oz fabricated and tig welded washer fluid tank with auxiliary light mounts.
Allows up to a 7” light to be mounted behind the grill. Max height of 7.4”.
The washer tank mounts in the oe location and uses the oe pump, sensors, seals and filler cap.
Mounts are laser cut and tig welded also and bolt to the radiator support using oe hardware. Super rigid design with no deflection.
How much?
Sorry, don’t have my RHO yet so I can’t look behind the grill. Are you building the tank because you need to relocate the washer fluid tank to fit these lights?
I currently have a 40” light bar hidden below the lower grill on my 2020 Laramie, and I’m really going to miss the light output on the RHO unless I can get something like this sorted out!
Also, OP - very well done on the fab work!
Correct, the washer fluid tank is in the way and not much room to relocate it.
What diameter light can this kit accommodate??
Tank $399.99
Mounts $179.99
Stacking dimes!
Beautiful work!
