RHO Running Board Height
hhhoggg
South Florida
2026 RHO LVL 1 Diamond Black
Hey guys, looking for someone who can tell me the height of the factory non-motorized running boards from the ground on a stock height RHO. I’m 6’2” and the wife is 5’5” and she already complains that the running boards on my Raptor are too high. I’m debating on the electric boards but I prefer fixed. Any info would be greatly appreciated.
I have the Ram power boards. Luv ‘em, but…
There’s a reason Ram doesn’t offer them as a factory option.
If you do any off-roading, they have lots of moving parts…multiple hinges & such. They weren’t really designed to get dirt or mud slung at them. If you do get them dirty, you’ll need to spend some time carefully cleaning & lubing, or they will grind & likely fail over time.
So, if your RHO won’t be a pavement princess, stick with a fixed board & get a style that suits your wife’s needs.
17" to the top of the board.
Good info and makes perfect sense.
I’m in South Florida and won’t be going in any mud on purpose, maybe a job site here or there. That said, I do a lot of fishing and down here we have a lot of shell rock roads and that stuff is nasty. It’s like talcum powder and gets in everything. It is worse than mud. I end spending 2 hours cleaning my truck and boat after fishing depending on where I go, sometimes more.
I mentioned the power boards to the wife and she already has her mind made up but I’m not so sure now…
The power boards are really great. You can control them from your center screen. They deploy when approaching with key fob. You can lock them down when parked to prevent door dings.
But, dirty driving conditions require some extra TLC on your part.
Nice! I didn’t know they deployed as you approached. That’s a great feature
I had the Amp research power running boards on my last truck and loved them. Living in Wisconsin with our winters and all the salt used on the roads had no issues with them. Only maintenance I would do like once or twice a year, would spray lubricating oil in the hinge areas (not sure if I needed too).
Only reason I don't have them now is I wanted to try the factory steps to see if they would protect the black paint better. Only had the truck for almost 3 weeks, so still checking it out.
One thing I do really miss about them is how low they go. I'm 6' so not real an issue, but have severe arthritis in my spine so I have days its very hard to actually get my leg high enough to get in without too much pain.
They are plug and play as well.
I think the Amp Research XL's drop lower than the regular or Mopar boards. Not as clean an install as the Mopars but better than many of the others that require a switch inch door.
That's what I had, they kind of looked like rock rails . This is what they look like. I would do those again.
Someone had a bad day in their RHO. Pic from duning forum. Who has the oldest unfulfilled order? ISO LP6 light bracket JANUARY order updates! Celebrating 100 Orders Can someone help me with an update?
