Timber grove air bag removal on RHO
Ctech-Review
25 RHO
Braptor
Dune day tomorrow going to stretch the legs on the RHO, and I decided to remove the timbergrove Air bags...was going to do some off roading with them installed then realized I wanted to see what this stock RHO can do and not limit rear travel.
PSA: I was able to keep frame side and axle side mounts in place and just remove the air bags in the middle. Easy job, took like 15 minutes tops to remove both. I will see after tomorrow use if the upper or lower mount come in contact with each other with out air bag. Steve at Timbergrove said according to his math when he designed this kit that it should be fine and no interferance with this setup with full suspension compression and mounts not touching...stay tuned!
This is what I did as well even for daily driving, easy process to remove and reinstall the bag
I have them sitting in a box in the garage. How is daily driving while they are installed? I've watched your videos but don't recall you talking about ride without a trailer.
