Tire pressure
Jrock
Range Rover 2016
Audi S5 Sportback 2019
MD set all the ties at about 44PSI. I have lowered to the door jam recommended 38, but was curios as to what you all run on the street and why? Also does the 38spi that’s recommended support the max payload capacity and if I wont typically be going anywhere near that level should I lower a bit further?
For full transparency, I go so excited when I got the truck I did 300 miles with the 44 PSI and the truck was still incredibly comfortable. I just deflated to 38, so not sure if I will be able to tell the difference on the seat of pants test.
OK so no replies… I started messing around with ChatGPT to educate myself on factoring in PSI for load, towing/ off-roading . After prompt engineering for 10 minutes and giving it the data it required it came up with the following…
On all previous road vehicles I have owned, there hasn’t been a need for me to tweak PSI outside of what’s recommended, so this was learning process for me that may help others.
ChatGPT Created this cheat sheet based on the stock tires, with the details of how it arrived at these recommendations further below. (I=ChatGPT)
The on-road recommendations seem straight forward and accurate, I dont have any experience with serious off-roading so when I get some more time will have to verify the accuracy of those.
1. On-Road Tire Pressure Recommendations
How I determined PSI:
• Your tires are LT325/65R18D (Load Range D) with a Load Index of 121 (3,195 lbs per tire at 50 PSI).
• I used standardized LT-metric load/inflation tables (published by T&RA and manufacturers like Michelin, BFG, etc.) to correlate pressure with real-world load capacity.
• Your truck’s curb weight is 6,283 lbs, divided over four tires = ~1,570 lbs per tire when unloaded.
Why the PSI ranges:
Scenario
PSI Range
Why
Unloaded Daily34 PSIMatches actual weight; smoother ride without risking underload wear.
Moderate Load38 PSIManufacturer’s doorjamb recommendation; balances performance, safety, and fuel economy.
Heavy Load / Towing40 / 44–46 PSIIncreases rear capacity for safe towing, per load tables.
Max Payload/Trailer42–44 / 46–50 PSIApproaching GVWR; tires need full inflation to hit 3,195 lbs each.
2. Off-Road Tire Pressure Recommendations
• Based on experience from off-roaders, trail mechanics, and tire physics: lower PSI = more traction via increased surface contact and sidewall flex.
• Each terrain favors different characteristics—some need grip and articulation (rocks), others need flotation (sand).
Why the PSI ranges:
Terrain Type
PSI Range
Why
Highway to Trailhead34–38Normal inflation is safest for paved roads.
Packed Dirt26–30Reduces jarring and improves traction on loose gravel and washboard surfaces.
Rock Crawling18–22Maximizes tire flex for grip on boulders, but risks de-beading without beadlocks.
Deep Sand / Dunes12–16Large contact patch prevents digging in; ultra-low pressure increases flotation.
Desert Running22–28Mix of traction, control, and heat management at speed.
3. Beadlock Recommendations
How I determined PSI cutoff:
• Based on common off-road best practices and failure cases from tire shops and 4x4 forums:
• Standard wheels rely on air pressure to keep the tire seated on the rim.
• Below 15 PSI, the bead begins to lose its grip—especially when turning or articulating.
• Below 10 PSI, you’re depending on luck and sidewall stiffness unless you have beadlocks.
Why the beadlock cutoff:
PSI
Recommendation
>15 PSI
Beadlocks optional
12–15 PSI
Beadlocks recommended for frequent use
<10 PSI
Beadlocks strongly recommended
<8 PSI
High risk of de-beading without beadlocks
This is really good info - thank you (and ChatGPT) for putting this together.
I'll target 35/36 psi in mine
Damn, this is great, thanks!
