Traditional Gauges HELP!
RADA
Apple Valley, CA
2025 Forged Blue Metallic L1 Service Queen
USAF
Okay, I need some help..
I'm trying to set up the Traditional Gauges for Speedo and Tach, but they don't display after hitting the Up Arrow to "Save & Exit."
What am I doing wrong?
Thanks!
Thanks!
You just need to hit the right and/or left arrows on the left side of the steering wheel when you are in the main driving information screen (speed and/or tach are showing). When your preferred configuration shows, leave it be. No need to hit any “save” button.
You just need to hit the right and/or left arrows on the left side of the steering wheel when you are in the main driving information screen (speed and/or tach are showing) When your preferred configuration shows, leave it be. No need to hit any “save” button.
I'll give it a try after work.
This didn't work.
I select the Traditional Gauges, and it just stays there indefinitely..
Might be able to get you a recording in the morning (unless someone else does first ) - my rig is still being Xpel’d
I do remember it being a little tricky until I realized there were 2 screens that include the tach/speedo
One screen with digital speed between the 2 gauges … and one with max speed in the middle and actual speed between the 2 gauges
This didn't work.
Same thing happened to me when I hit that guage button on the steering wheel. Tried every button to get out lol. I think I just held the right button down for a few seconds to get out...
I tried going through the Owners Manual... yeah, that was less than helpful.
If someone knows how to lock in the Traditional Gauges, I would be grateful...
Sorry totally forgot … I’ll try to track how I got there later tonight
What gauges do you currently have displayed? I'll see if I can help before my Ohio State Buckeyes kickoff to kick some ass!!
Starting screen:
Screen Setup:
Select "Traditional Gauges"
Select OK:
Even after all this, no gauges...
If I don't hit the up arrow to exit, it will sit here indefinitely.
Ok. From your start screen, just start using the up arrows
I think you need to go up either 2 or 4 clicks
Just ignore the screen set up. From your start screen, just use those arrowns on the left side of steering wheel to scroll up/down until you get to the Speedo/tach screen.
You’ll scroll up and down to messages, audio channels, fuel economy, etc. Go until you land on the Speedo screen
Yeah. Its weird. You’re just telling it what to choose, but not actually telling it to go to the screen. Once you’ve selected it, you need to scroll through to the proper dashboard screen and you should see it.
I've scrolled through everything available. It's never an option after saving it.
Ok. I’ll try to navigate the screens you’re on tomorrow morning, and report how to get there.
I have a a scheduled date! I’ve had my RHO for 5 days Marker Lights Mopar Bed Mounted Spare Tire Carrier Wheel question - which is correct backspace for RHO - 5" or 5.79" *** Post New RHO Photos Here ***
