Wind noise 45mph+?
Rebel2RHO
2019 Ram Rebel
First off, just over 3000 miles and the truck has been pretty solid minus a headlight swap for a buzzing sound.
Does anyone have wind noise coming in through the driver side door/window area 45mph+? Visually all the seals look good. Will probably make an apt to have dealer look at
Yeah I have this too. It's very slight and I'd rather deal with it than have them start ripping stuff apart.
I noticed it during the 1st month of ownership. Don’t notice it anymore. Don’t think it’s changed… just got accustomed to it.
Yup have it as well. I believe there was a tsb for it on the trx
Same issue for me at 15 miles on odo but it’s on passenger side front door area ram knows about the issue but no fix currently
I have one buzzing headlight as well. Don't hear it inside the truck, not gonna have them tear shit apart either...will go in if it fails.
Mine doesn’t have this. My 2020 Ram did, though, and it sounded like the doors were going to fly off if I had a strong crosswind. I probably should have sought out a solution in hindsight…
I have a buzz when the truck is in the garage. Not sure if it is headlight or normal other sounds. Suppose I’ll have to look into that one.
If you walk up to headlight after truck is off, but headlight on it will be easy to tell if buzz is coming from the headlight. If you have a good dealer/service department shouldn’t be a big deal to swap headlight under warranty if that’s what it is
