2025 RAM RHO/TRX Reverse Light Kit | M&R Automotive
MandRautomotive
Supporting Vendor 🛒
2025 RAM RHO
2000 Dodge Viper
Fits 2025+ RAM 1500 RHO
  • Each kit comes as a PAIR of pods
  • main White LED light -- you choose your backlight (amber or red)
  • 1) Amber back light that can be wired as turn signals
or
  • 2) Red backlight that can be wired as turn signals or break light
  • Driving Flood Pattern: longer and wider beam focuses for illumination further down the trail or road as well as peripheral angles
  • Each LED light pod is attached to a metal bracket on each side
  • Metal bracket is powder coated black
  • This in addition to factory reverse light. The factory reverse light doesn't provide enough light output at night. Install M&R reverse light with powerful white LED light that makes a huge difference
  • No cutting or drilling required. The kit is a complete bolt on
Introducing our brand new LED lenses-PRO series with a unique appearance and optimal performance.
  • Uses TIR (Total Internal Reflection) lens is different from the conventional optics parts, which lose some light internally and produce glare. The TIR lens collects all of the light from the LED and directly leads them to where you need, drastically reducing glare and improving total efficiency.
  • Higher light efficiency: brighter, longer irradiation distance
  • Housing is upgraded to 304 aluminum. The surface is UV polyester powder coated to prevent against UV, salt water, corrosion, fading and scratch resistant.
  • Equipped with thermal management system that automatically adjusts the brightness output according to the external temperatures
More information on the RAM RHO reverse light can be found here
How difficult is the wiring install on these? Where did you run the wires?
We connected them to AUX switches. Just extended wires from the lights to the odd area around the frame
Performance at night
If they are wired to the aux switches how do you tie them into turn signals or brake lights for the backlight? What if you want them to come on when put in reverse? Are they lights that would blind people behind you when backing up? I would love to have these to help with seeing with tint on front windows
You could wire them to the 7pin trailer connector. There is a pigtail adapter I used for a homemade version of these lights several years ago.
Using that method on some trucks (havent tested RHO) sometimes deactivates rear sensors and lane assist in our experience
I did it on a 2019 Laramie. I have not had issues with lane assist, blind spot, or rear sensors. The lights I used are much smaller than the ones in the original post, not sure if that would make a difference.
I'm running trailer connector on rho on mine for 3 weeks already with zero issues. Super easy install didn't even need to lower spare.
ordered and looking forward to delivery - like the mount bracket - keeping the lights tucked up close to the bumper and protected .... seen many where the u-bracket is angled straight down
Got em installed this weekend - worked out great - brackets and hardware were perfect - hardest part was digging out the accessory wiring from under the fuse box .... RAM has that tucked and taped in there good.. Video install covered everything well.
