Late 2025 Build Issues?
eruss
Hey All,
Thinking about pulling the trigger on an order through MD on a 25.
Have any of you with trucks arriving more recently seen some of the same issues as the early trucks? I totally understand most things wont be addressed until 2026 or even 2027, but have some of the small problems been fixed? Loose fuses, headlight harness etc.
Would consider a 26 but will likely lose out on a lot of the discounts.
Thanks in advance!
Mine was built around Christmas and I had a few minor problems so far. It's actually been at the dealer for the last week to fix:
1. Truck was slightly pulling to the right, wasn't too bad but very annoying. Could be dangerous also.
2. Proximity lighting would not work no matter the settings, dealer is researching a fix with manufacturer.
3. Cameras wouldn't show overhead parking view when pulling into a parking spot. Dealer fixed with software update via manufacturer assistance.
To date, actual failures on mine are
- AUX battery failed, fixed under warranty, symptoms CEL, Blind Spot monitoring needs service, auto/stop studdered, under CEL remote start gets disabled (by design)
Vehicle Built - Feb 7th, Actual Delivery - Feb 24th
Hey All,
Thanks in advance!
L0 at 500 miles… knock on wood no issues so far
350 miles and at the dealership due to check engine light. Been 3 days of troubleshooting but I am sure they will figure it out. Love the truck and do not regret buying. Picked up truck on 3/10
Mine only has 310 miles on it. Just left the dealer, it wasn't ready yet. I guess it needs a front end alignment after all. It came from the factory like that. I was telling the dealer it was pulling to the right from day 1 but no one would believe me until the service manager finally test drove it.
Mine is pulling too... i thought it was in my head but now seeing this post im taking mine in ASAP.
I’ve taken mine in 3 times and they’ve tried with no luck of fixing!
Why? If you say you have an issue they should check it and fix it... alignments are easy to diagnose so is it your dealer? Maybe go to another one.
My Limited was built in Late 11/2024 and it has the Proximity lighting issue. The led on the FOB also doesn't blink like it should when you approach
the vehicle. My first attempt to have my local dealer look at it and the camera issue which I also have was an exercise in futility...
Where can I see where my truck was built and when?
I just noticed a buzzing sound coming from my driver headlight at 750 miles… any insight is welcome
TaZer DT for RHO RAM RHO HO Downpipes with High Flow Cats +100hp! Lights and Lightbars Where is IGM Auto? Service shifter In-Stock Now for your RAM RHO: Vossen HF6-4 Wheels @ JustBoltons.com
