Not a "problem" but surely wondering why? Engine Start/Stop
I honestly haven't turned the climate control off from being in "auto" for the 1000 miles I've had the truck --- I suppose I should give that a go.
That's probably the reason. If on auto, likely the A/C or heat is always on in some capacity, likely negating the start/stop "feature".
I am almost at 5,000 miles and mine has never shut off. I live in the Tampa area and a/c is always on. I have not once pushed the button.
I picked mine up in December. I live in Ohio. Heater was on until late April, so never had the start/ stop function shut the truck off until spring time. Then I had to remember to disengage that abortion of a feature each time I started the truck. After forgetting to do that a couple of times, I purchased the Auto stop eliminator. It was $100 well spent
Mine also rarely works (shutting off motor), but recently its started doing it more often, I am also in Tampa and have only had the truck 3 months so AC is typically on
Surprisingly, here in Texas, before I installed the disabler, it would do it all the time....so glad that is over and I dont have to remember to press the button( I know, first world problems)
We all likely can't stand the auto engine start/stop feature on our vehicles -- most of us typically purchase a dongle to delete the feature --- well, my new RHO hasn't start/stopped yet -- I'm currently at 1,000 miles. The light works if I press it, but under normal conditions (light not on) the engine has never start / stopped) . I wonder if I disabled it in the settings somewhere and don't remember it was even an option, or it's broke (and that's fine with me).
Any idea?
Same here! I have brand new 2026 and it has yet to start/stop!
so let me see if understand correctly -- you had the same experience as me, where it never worked -- and then all of the sudden it decided to start working? Software update perhaps?
Are you light on the brakes... If im light on the brakes coming to a full stop I can make it not shut off...
I think we're onto something here.. it just doesn't work 😅
Look at this BS.... at a stop light, foot on the brake and the message says not ready because the pedal is depressed LOL.
This is the way
My bad. I misunderstood the error displayed!!
This is being looked at all wrong... How in the hell do I get mine to do that... I wanna trade my Illumination message for that one. You're so F'in lucky... Buy some lotto tickets asap. 😉
Dealer master tech diagnosed the issue with Stelantis as a faulty throttle pedal APP Sensor -- causing both the lack of start / stop and the loss of throttle / power I experience intermitently. They also diagnosed a faulted module in the infotainment not allowing digital key or update. Gotta say, they treated me well -- even added fuel back to truck they spent during test drives. Anyway, the tech did say if you're at a stop and you physically lift up the accellerator pedal, you may get start / stop to engage -- tell tale sign of a bad sensor in the unit. Parts are ordered -- pedal sensors (known issue) in stock, infotainment module - back ordered.
Die Cast or 3D printed RHO Picking up Trucks that have been leveled or lifted RHO Delivered Instock Available RHO's at Mark Dodge 2025 Ram 1500 RHO tonneau cover best value option for off road use? Tonno Pro Lo Roll
