- Oct 12, 2026
- 35
- 2
Technical Service Bulletin · TSB 08-418-26
Published: Nov 6, 2026
Applies to: Ram 1500 (2025–2026 model years)
Details from NHTSA as of Nov 13, 2026. If NHTSA or Ram revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Summary (official text)
Accelerator Pedal Output Non-Zero with Pedal Released Customers may comment on one or more of the following: SYMPTOM: ● High engine idle speed may be observed. ● "Engine Stop/Start Not Ready" message may be displayed in the Instrument Panel Cluster (IPC) and/or Engine Stop/Start (ESS) system is disabled or overridden. ● Adaptive Cruise Control (ACC) may not function as intended. Following distance may not be maintained, or a message may be displayed in the Instrument Panel Cluster (IPC) indicating driver override of cruise control. ● No Diagnostic Trouble Codes (DTCs) may be present, as this condition typically does not set accelerator pedal-related DTCs. This bulletin involves diagnosing the accelerator pedal position signal and, if required, replacing the accelerator pedal
Sources
- 08-418-26 (PDF, NHTSA document 11039911) — Nov 6, 2026
