TSB 2025 Ram 1500 Digital Key Control Module (DKCM) — 08-423-26
Technical Service Bulletins
Imported from NHTSA data · last checked Nov 26, 2026
RamRHOForum
Forum Support 🛠️
Technical Service Bulletin · TSB 08-423-26
Updated Nov 26, 2026: Summary, documents added, supplements (details)
Published: Nov 11, 2026
Applies to: Ram 1500 (2025 model year)
Summary (official text)​
Digital Key Control Module (DKCM) Customers may experience a Malfunction Indicator Lamp (MIL) illumination and the vehicle may SYMPTOM: exhibit/set one or more of the following Diagnostic Trouble Codes (DTCs): ● B22A9-00 - ECU Internal Performance. NOTE: The following DTCs will be set together as a result from the FOTA Roll Back Failure and the vehicle will also have a blinking odometer: ● B2204-87 - ECU Configuration Mismatch-missing Message. ● U01EB-00 - Lost Communication With Key Control Module. Customers may also comment on one or more of the following: ● The Digital Key is successfully paired; however, the Lock/Unlock, Panic, and Remote Climate controls are not displayed in the phone wallet even though the device is eligible for these features. ● Vehicle proximity/welcome lights activate excessively when the customer is near the vehicle while carrying their paired phone. ● The Digital Key tile is not visible in the vehicle radio interface. ● A Firmware Over The Air (FOTA) update failed and the message "Visit the Dealer" is displayed on the radio screen. ● Unable to add a Digital Key to the vehicle / pair a phone in the Digital Key app. ● Customer is unable to see the Digital Key tile in the radio or the Global Mobility Application (GMA) / Ram App. ● Customer accepted the FOTA update multiple times, but the Smartphone as a Key (SPAAK) / Digital Key functionality was not enabled. This bulletin involves inspecting the DKCM for DTC "B22A9-00 - ECU Internal Performance" or confirming that the Telematics Box Module (TBM), Security Gateway Module (SGW) and the Radio Frequency Hub Module (RFHM) are already updated to their latest software levels and possibly reprogramming the DKCM
Sources​
Details from NHTSA as of Nov 26, 2026. If NHTSA or Ram revises this notice, this post is updated and significant changes are noted in a reply. The linked documents are the authority, and a dealer can confirm whether it applies to your VIN.
Update from NHTSA (Nov 26, 2026): TSB 08-423-26 has changed.
  • The official summary was revised
  • New document: 08-423-26 REV. A
  • Supplements now listed: Rev. A
The opening post has been updated with the current information.
RAM RHO Behind the grille auxiliary light kit 👌 Running Boarda for Kids -RHO October Sneak Peek + Limited-Run RHO T-Shirts Eibach springs 2026 RAM RHO Order/Schedule/Build Thread What color Ram RHO will you buy?
