2025+ RAM 1500 RHO / Rebel 23in Light Bar - PRO
Installed my 23" Pro Bar today (as I mentioned in another post the installation process was a pain in the ass). Adding the reverse lights tomorrow. I'll try to add some pictures. Note: The reverse mounts aren't marked (i.e., driver/passenger). I'll figure it out but it would have been nice to have them marked like the Pro light mounts were.
Noted, thank you for the feedback! We are looking forward to seeing the pics once installed!
Thank you for your support! Post pictures once it is installed!
Installed the new M&R 23" Pro light bar today. The overall install was pretty easy. The hardest part was getting the clips on the filler panels loose. After that, it was smooth sailing.
The included heat shrink butt connectors were a nice touch. I did run into one minor issue: the end of the light bar is slightly angled, but the brackets are at a 90-degree angle. I had to bend them a bit by hand to get them to sit flush with the grill.
Happy with the final results! I tried it at night and it adds a great fill to the brights.
Here are photos after the install. It was midday so they're a bit washed out.
Looks amazing thank you for sharing
Finally got around to taking a few pictures of my lights well, on. The third one is just the 23" pro light bar and the 4th one is just the pro ditch lights (no headlights on those last two).
Who needs the sun with you around? ๐Ÿคฃ
Hey everyone, we hope you all had a great holiday season and a happy new year! Let's start this year off strong with some of our badass light bar kits. You can use coupon code COLBY10 at checkout to get 10% off of your purchase. Check out the link below!!
2025+ RAM 1500 RHO Light Bar Kits
Hey everyone, you can still use coupon code COLBY10 at checkout to get 10% off of your purchase. Check out the link below!! Here is a quick installation video to show you just how easy our kits are to install.
Has anyone tried to fit this light bar without removing the grill? If so, was it as easy as the video would suggest.
I did. I would say itโ€™s as easy as the video makes it appear. The only issue I had was I could not rotate the brackets fully as the video says to do as it caused the edges of the brackets to protrude past the edge of the light and it would not fit in the spacing in my grill. Do not try to force it in or youโ€™ll gouge up your bumper/grill. If it wonโ€™t fit back off the rotation of the brackets around 5 degrees so the edge of the bracket does not protrude. After I did that it slipped right in.
I wired the amber DRL to Aux 2 and programmed it to remember the last setting so it comes in automatically when I start the truck. Keep in mind if you do that the DRLโ€™s will be on whenever you have the truck in the Run setting, even if the truck is not running (i.e.: if listening to stereo). But you can just turn Aux 2 off in that circumstance. I wired the white lights to Aux 3.
โ€ฆunless you have very short arms it should be an easy install. ๐Ÿ˜‚
The most difficult part might be accessing and freeing up the Aux wire harness next to/under the battery.
I used a sharp Xacto knife to carefully cut the tape that secured it in place. Itโ€™s not easy to get to.
I installed mine about a month ago. You do need some skinny long arms but install was very easy!
I took my grille off, so easy even a trex could do it. ๐Ÿ˜‚ But I also didn't know it could be done without removing it to be honest.
(2025) RHO Orders @ Mark Dodge! $9K-$11K Dealer Discount (Before incentives) RHO specific k&n intake now available Exoctic Innovations What did you do to your RHO Today? 2026 RAM RHO Order/Schedule/Build Thread Is your RHO one of a kind?  Let's find out.
