2026 Ram Rho Overland Build
neoprufrok
Hi all, wanted to introduce my RHO and the build thread. First, I love this truck. Second, I love off roading/overlanding whatever you want to call it. So why did I get a RHO? Well... first things first. I have a Jeep. It's a 2024 392 JL370 built by AEV. I've built it out and have gone everywhere with it. Pismo Beach, San Rafael Swell, Table Mesa Upper Terminator trail, Rubicon. I love it. Can go everywhere. After this July doing the Rubicon the first time, I'm turning the Jeep into a more rock crawler camping build. So 39" tires, new axles etc. That said, the Jeep is limited for longer overland runs to places farther away and for long trips. It can be done, but limited in carrying stuff my wife and dog would want to go with. So, I initially thought I wanted a Ram HD PW. But even with the Diesel out, it was just too big for daily driving (yes this also needs to get me to work). While the RHO isn't small, it's not as long. Finally, I do care about on road perforamance and fun. Hence the 392. And now the RHO. Why not the TRX? The RHO is better for overlanding to me. Better mpg, better payload, less weight on the front etc.
So with that, I set out to get a RHO and I went back to the dealership that has treated me so well - Ellis Ram Jeep in Glendale, CA. They had essentially the one I wanted. Level I. Pano sunroof. Running boards. And black. I actually drove it to Vegas than back to the bay. I love it. Super comfortable. Luxurious. Has all the amenties I need. Also.. has massive presence. It for sure looks the business. Gripes? Camera system slow to respond. Interior exhaust noise is nonexistent.
Here are some pics from the drive.
The first thing I wanted to do was to paint prep the truck and PPF it. I do this for all my cars (I have a car habit) and for my Jeep it's been necessary with the amount of pinstriping I've had on the trail. The orange peel is horific. But after an amazing true compounding, polishing folowed by PPF (Detail work - The Car Connoisseur, PPF - Mykos Design). It looked pretty nice (my Jeep is next to it):
I also had beige RHO decals done by Rocky Mountain Graphics. I wanted tan, but beige seemed closest in their color selection. The idea is to complemetn the colors of my Jeep which is Gobi Tan and black.
After that was the wheels. So I spent way too much time researching this. I wish RAM offered the 37" as an option. 37" is perfect for overlanding. The thing is, I also don't want to start adding height. On the trail, keeping the COG as low as possible is important. I also think changing springs etc can change the OEM driving dynamics - which I think is great. So I watched this video by Ali Mansour of Driving line:
He was able to run 37s without rubbing or changing anything on the suspension. I chose this as inspiration. I wanted to go with Method 709 HD (18x9 et12) in Matte black with Toyo Open Country R/T Trails (37x12.5) because this would be almost the same weight as stock beadlocks with 37" tires. Was also excited to see Tire Rack selling both. So I called them, unfortunately, Toyo was backordered till January. So I replaced with Nitto Ridge Grappler R/Ts which are also great, just heavier. The spare was an issue. My build wont' allow me to carry a spare in the bed. On my R/Ts or M/Ts I've run I haven't had a flat. I also carry a significant tire repair kit from ARB and Gluetread. So I kept the 35" and the idea would be to use Z Synapze DT to switch to 2wd mode - and put the 35" on the front and limp off trail till I get to somewhere I can get help.
Here are the first few pics... without the Method Protection rings. It looked good, but the wheels seemed a little off to me
So... I kinda knew I wanted the protection rings, so I ordered them separate from CJC off road (Tire Rack doesn't carry them). I installed them... to me looks a lot better. Also, as I offroad a lot, it would offer protection and an easy way to replace the damaged ring without worrying about the wheel. A note on the bolts for the protection ring - there's a lot of them. And some of them were tightened at the factory super tight. some were super loose. Who knows. And that takes time removing every bolt (which you can do while on the truck as it's not a beadlock) and then reinstalling and torque wrenching each bolt. But it was worth it:
I also added a Retrax HD Pro Manual. Why manual? It's lighter by like 50 lbs. For me, trying to build an overlander without going way overweight - any weight I can save, would be great. So I orderd one from realtruck.com. They have been great. Took it to my warehouse where I keep some other cars of mine and my friends.
Question is, can you install this by yourself? Yes... but I have a hoist... so that helps a lot. Install was generally straightforward.
So next up was the Z automotive Synapze DT. Why? Well as mentioned before I wanted the ability to 2wd in an offroad situation. Also, I liked the idea of the Amber DRLs. Finally, being able to keep start/stop and staying in my Custom mode (basically only change is sport suspension). Updated firmware and installed - which was easy. It was working well. WAS is the key word which I'll explain later. Here's the nighttime DRL.
So next up was the big daddy. I ground tent. But may be adding a lightweight rooftop tent later. But overlanding it's nice to have some extra storage to carry things above the bed. I chose Leitner Designs for my bed rack. It looks great, it's light-ish (165lbs with all the accessories added dry) and the ACS Forged Tonneau version is designed to bolt onto the Tslots on the tonneau cover. Yes I planned it this way. I got this through Overland Kitted - love them. Owner is a true enthusiast. It was an all afternoon affair by myself, but very doable. Everything fit perfectly. Minor nitpick - they're are T30s, but then the manual says Allen. Either socket was easily stripping the bolts.. so had to be super gentle. I also got the headache rack from them - which is perfect. Can see through it backwards without issue. Aesthetics fit perfectly with everything and even has a molle panel to attach stuff.
Daytime pics. I love how it worked out. Also I washed and protected with Griot's Garage 3-in-1 Ceramic Coating. I am biased.. but I think the truck looks super dope.
So... not everything is groovy. A day before these pictures I got a CEL. I used the Synapze DT and checked, and AI told me it was can bus communication codes. I cleared them and nothing happened. A few days after this, driving to work... the truck went into limp mode and everything electronic seemed to be turning off. This really sucked on the highway. I got it to my parking lot, and shut it off. Waited a few minutes restarted and it was fine, with a CEL. Had to go to work. Later, before driving home, I checked the CELs.. and it was a ton of electrical, communication errors. I cleared them then started driving. Halfway home, it did it again.. i pulled off an exit to my favorite jeep shop, 41 Designs in Campbell... and before I got there I had to pull over it just didn't seem right. Problem was, it wouldn't go into Park and... THE ENGINE WOULDN'T SHUT OFF. So I called my buddies at 41 Designs, and they came over. I tried everything the internet said to shut it down. Last ditch was to pull the negative terminal.
So we did that... AND THE ENGINE WAS STILL RUNNING. The alternator was keeping the electronics alive. So we pulled the fuel pump fuse. Which did shut it down. I mean, to say I was mad is an understatement. I restarted and it seemed ok for 2 minutes.. then did the same thing - Christmas tree lights, can't shift, engine doesn't shut off. So I was thinking this has to be the Synapze - must be confusing it. So i uninstalled the Synapze DT. Restarted.. and it was fine. After getting it to the 41 Designs shop, we checked codes - same CAN bus communication faults.. and cleared the codes. I've driven for a week and it's been perfectly fine. So i have decided the Synapze is not worth it at this time.
I emailed Z Automotive on wednesday (today is Saturday). Haven't heard anything.
I would resolutely not recommend the Synapze at this point. Going into limp on the highway twice and not being able to turn the engine off? This is HORRIBLE.
These are just a sample of the codes.
Final thing I did today. I added the bedboss lite. Basically it's a 60lb composite bed floor you can insert rivets, e-z loks etc to then strap down equipment etc. Unfortunately, dumb me didnt' realize it wouldn't fit if I had the tonneau and leitner on. So I had to bring the truck to the warehouse, hoist the Leitner and Retrax as one unit, go home, install the bedboss and then go back to the warehouse to bolt on teh Leitner/Retrax.
The bed boss install is not complete. Why? the bolts and brackets don't line up. So... I'm waiting on their response. It looks great and I'm excited to be able to start planning how to strap down my fridge, power station, milwaukee packouts etc.
RHO Wheel spacers 2026 RAM RHO Order/Schedule/Build Thread Down pipes!!!! Electronic safety systems unavailable, limited functionality…service required Post your favorite picture of your RHO Method Race Wheels 12% Off until 5/1/2026
