Any bed dividers similar to Fords?
rochell59
Austin
Hey there,
Are there any Mopar or aftermarket bed dividers like the Ford one below? I'd like for it be able to stow away to the sides if possible.
Thanks!
There used to be a mopar one, idk what the part number is tho. They stopped making it
I got mine off of Amazon. It’s identical to the Ford one I had in my raptor. Pretty sure I paid about 100 bucks for it. When I get a minute I’ll try to dig and find the link.
The bottom sides of the bed opening on the ram are curved so you will have to space it in a little narrower. I’ve cut 1/2 inch thick, hard black plastic strips to mount it too.
Thank you! How did you connect this to the bed? Did you have to drill and tap for bolts?
I haven’t had a chance to install it yet. I’ve cut 3 inch wide half inch thick black hard plastic strips. I’m going to drill through and riv-nut those to the bed in all four corners. I am going to drill through at the center pivot position and put a large riv-nut there and then drill holes in the plastic for the spring loaded pin to lock into. All thread inserts will be on the bed metal.
The plastic strips are to give it clearance so it doesn’t hit at that curve at the bottom edges of the bed sides. I may have to get three-quarter inch thick plastic once I really get everything measured out. Either that or double up on the half inch.
Deleted thread Aussie Ram HO engine but not a HO we missout I have a a scheduled date! RHO Mud Flaps Ceramic Coating - Need Opinions Bed Utility Group and Bike Rack?
