Bed Step Recommendations
Son of a b*tch. Going back. Says it's supposed to work with '25 on Mopar site so I just assumed it work with a '26 Screenshot_20260131_140604_Chrome.webp Oh well.
Please make sure you are buying the right MOPAR step. The 2025+ is different because of the updated rear facia. Even Mark Dodge got this wrong when they installed mine. It will fit, but will slam the hell out of your lower facia when it closes.
Pics are the correct step and if you look close you see the differences.
100% - I bought the wrong one. 82216597AC is the part we need.
From Gemini AI:
Yes, Mopar part number 82216597AC is the correct official bed step for a 2026 Ram 1500 RHO.
While earlier model years (2019–2024) used a different part number, the 2025 and 2026 Ram 1500 models—including the high-performance RHO trim—feature a redesigned rear bumper and lower plastic molding that require this specific updated version.
Key Details for 82216597AC:
Compatibility: Specifically designed for 2025–2026 Ram 1500 models (all trims including RHO, Rebel, and Tungsten).
Important Note on Older Parts
Be cautious of aftermarket steps or older Mopar part numbers (like 82215289) labeled for "2019+ Ram 1500." On the 2025–2026 models, these older versions often hit the bumper trim or do not retract fully because the new bumper design is slightly deeper. The "AC" suffix on the current part number indicates the latest revision meant to clear this updated bodywork.
For those looking for a step that WILL FIT 2025 RHO ..... I FOUND ONE ON AMAZON FOR $255.00
There is a slight imperfection but for the most part IT FITS AND WORKS AS IT SHOULD!! Without spending 400+ from mopar website. The slight hiccup is that it doesn't go into the frame hole as it should but when you tighten the bolts up its fine. With the extra bolt and nut they supply with the kit is for the third hole. The nut is incase you don't have any threads on the other side of your application. Mine had them but I put on the nut just incase things came loose and that nut is my added security. For $255 I'm happy with it!! First pic shows where it doesn't go into the frame hole.
Will this void my warranty?
Clicked your link and it is now priced at $214 which is hard to pass up vs. the $450+ for the OE. I did see this in the description which has me confused, that PN is the correct one for the 26's. How's it been working for you?
  • Part Number: 82216597AC —— Compatible with Dodge Ram 1500 2024 2025 2026 (Not applicable to the 2026 RHO and TRX model)
Absolutely ZERO issues! The one thing I did notice was that it rubs from vibration and took some paint off the top of the step. But again no big thing I just ordered some rubber sticky pads from AMAZON and put them on the body of the truck. https://www.amazon.com/dp/B0CF2MZJXJ?tag=ramrho-20
(2025) RHO Orders @ Mark Dodge! $9K-$11K Dealer Discount (Before incentives) Starlink Mini, XBOX, and the front passenger screen! Blind spot monitor Post your favorite picture of your RHO What did you do to your RHO Today? May-April-June orders… who still isn’t scheduled?
