Cabin Filter Change
65coop
2025 RHO
Just in case someone has the same issue, I figure I would provide a my blower fan fiasco.
About a month ago, I replaced my cabin air filter and decided to try the lifetime K&N filter. It cost about the same as an OEM filter, so I figured I’d save money by cleaning and reusing it instead of buying replacements. The airflow from the vents seemed stronger, but the blower fan was also a LOT louder. It made an annoying roaring noise at the higher fan speeds. I thought I might have installed the filter incorrectly, so I removed it and checked the fitment. Everything looked fine, but the noise continued. I called K&N and spoke with a technician. They offered to send me a replacement because they had never heard of this issue, but I decided to return it and go back to an OEM filter.
I installed the OEM filter - and the roaring noise was still there! :mad:
At that point, I assumed the blower motor was beginning to fail and scheduled an appointment to bring the truck to the dealer the following Monday.
Over the weekend, I decided to investigate further. I removed the cabin filter and ran the blower at different speeds. When I switched it from low to off, I heard a faint clicking sound as the fan slowed to a stop. I pulled the blower motor to inspect it, and it’s a good thing I did! There were two acorns inside the blower fan that must have fallen in when I removed the original filter. I doubt that would have been covered under warranty!
How in the world did acorns get past the air-intake screen?
Needless to say, the blower fan is quiet again. For future filter changes, I made a cardboard cutout the same size as the filter. Not sure it will work, but I plan to slide it underneath the filter before removing it so it catches any debris sitting on top and prevents anything from falling into the blower fan again.
Thank You Veterans! 🇺🇸 Light Mounts Any Train Horns? RAM RHO HO Downpipes with High Flow Cats +100hp! 2026 models are live on Ramtrucks.com Positive owners experiences
