Confused tailgate... then dead RHO
dadbod
Seattle
2026 RHO
For Thanksgiving I went out of town and stayed at a sort of vacation spot outside of Seattle. While there, I barely drove the RHO... perhaps just a few blocks each day. Then, the night before heading home (after four days of next to no driving), I opened the tailgate remotely (while the engine was off). Surprisingly, the alarm went off... when I got the tailgate opened, then closed, and was in the vehicle, I noticed that the computer was confused about the state of the tailgate (it said that the tailgate was open when it was actually closed, and vice versa).
Anyway, after a short drive into town and back, I parked the RHO for the evening.
The next morning, I noticed that the tailgate wouldn't open at all. I got in the cab and noticed that the truck was dead (like dead-dead). I tried to jump it using a Subaru, but it refused to crank. I let it charge for maybe 30 minutes or so, but it still refused to crank. At that point, I tried two different things:
  1. 1. I tried to charge the secondary battery (but this didn't change anything).
  2. 2. I went back to charging the primary battery but I also found a second ground point that looked better than what I had been connected to.
Shortly after changing these two things, the vehicle finally cranked.
So, this sounds to me like a parasitic drain, but I sure wasn't fond of how the RHO wouldn't even try to crank while it was being jumped. This is the first vehicle I've ever owned that refused to crank the "old fashioned way" that I'm used to...
What do you all think?
Re: parasitic drain: I installed a dash cam that draws some current when the engine is off, but I've had this several weeks now and haven't seen any problems.
Lift or leveling kit? 37's? What did you do to your RHO Today? RHO range and MPG May-April-June orders… who still isn’t scheduled? How do you know if your 26 has the 100k warranty? Asked AI to modify my truck
