Didn’t know this was possible (Custom Drive Mode configuration)
RHOfan
Ram RHO
Yesterday, I noticed a button on the right lower screen that opened more options for the Drive Modes. Previously, I had my “Custom” drive mode set-up with the Transmission set to “Sport”. After hitting the “Custom Setup” button, new options appeared (see attachment). I can now have my Suspension in “Baja” with Transmission in Sport & everything else in Street.
It now rides like a Baja truck without the transmission holding shifts until 4500 RPM, like it does in full Baja mode. IMHO, truck even handles better with the softer suspension…turn-in substantially improved. I know, it doesn’t make sense, but that’s the result. Maybe something to do with revised stability control in Baja mode?
Has anyone else tried this? What are your thoughts? What other combinations have you found intriguing?
BTW, if anyone knows how to get the reverse camera to display guide lines that move with the steering angle, please share!
Thanks for sharing - I'll give this a try.
I wish the steering had a comfort mode - sport seems a little too stiff at parking lot speeds.
I think street is a little less stiff than sport (under steering option) ... ive been playing with the same mix myself
by the way - if you "click" customize setup - and then click the category you want to modify (select Suspension, or Steering etc) ... you can get an on-screen explanation of each setting and what it addresses - similar to whats in the manual
Cool!
Ive tried to do that today with suspension but it wont let me change to the baja (it goes back to street after few sec) do you know why ? Car is fresh with 150 MILS so maybe its disabled somehow ?
Did you select “Custom “ drive mode before hitting “Customize Set-up”? If you are in Auto (default), it will not allow Baja suspension.
I was messing with this today and maybe someone already mentioned it but it defaults back to Auto after every start? wth is that?
Yeah it does. Just like changing car into sport mode each time. It still saves the settings when you go back to custom. I was hoping Baja would be softer suspension but it is not.
2027 Black Level 1 is Finally Here! Overland- Let's see those racks, toppers, and RTTs Mid Feb built date issues? RHO Aux Switch Fuse Sizes New member from South Florida Does the RHO have what it takes to compete in the Baja 1000 like the Raptor?
