Dim the center screen?
FLRAMPilot
Space Coast, FL.
2027 RAM RHO
Retired Navy
With the headlight switch in Auto, the headlights come on as they should, but the center screen doesn’t dim. I understand that the screen dims independently of the headlights being on, but it’s nearly fully dark before the screen & gauge cluster dims, and when I’m using Car Play the screen is mostly white and REALLY bright!
What can I do to get the screen to dim earlier/when it’s brighter?
Have you tried rolling down the little dimmer wheel beside your headlight switch? If it’s clicked up past the detent, it will stay bright like that.
I went into the Uconnect settings and turned Off AUTO SWITCH in the screen settings. This way when you switch headlights ON or OFF screen stays the same Then you can adjust brightness manually with Uconnect settings and the lil roller knob by the headlight switch.
AH! That’s the ticket! Thanks Sarge!
@Eighty yep, makes no difference when the setting is in Auto. I’ll put it to manual.
RHO or 2500....... Trailer camera for trailer prep outfitted level 1 ? 2026 RAM RHO Order/Schedule/Build Thread Smoking deal on EGR Rolltrac Electric Bed Cover Apex Auto Styling (3rd party graphics) FRESH AS A FINE DOUGLAS FIR - Canyon Lake L1 Available at Mark Dodge
