Eibach springs
So if I have about .5-1.0 inch of clearance on my stock truck right now, leveling the front won’t raise the overall height at all? And I should still fit in no problem?
Your height won’t change if you just level the front. It only raises the front to match what you already have in the rear.
I park my leveled Raptor on 35s in the garage all the time. But, always check/measure.
I believe the raptor is not as tall as the RHO, I think its around 2" shorter.
It raises the front to allow more clearance for larger wheels/tires setup. 1.5 minimum is sufficient for most applications up to 37" tires on 18 to 22 in wheels. You still may need to use a heat gun and move plastic away from the turns especially if running negative offset wheels. But that is easy even a caveman could do it.
P
Pics are my truck. Haven’t taken any others besides this. The Chevy is leveled on 35’s. It’s a little deceiving but the stance is perfect with this combo. It has a factory style rake. Truck drives great!
What’s the height of the truck now after the tires/lift? Would you mind measuring to the top of the roof and fin?
What are the measurements after install?
I pulled the old kid on Christmas morning trick and didn't do a before and after measurement, but I can grab a measurement today when I get a chance
Lifted Trucks with another one. Kit and 37x12.50r20 on HFX-1.
Anyways, hopefully we see more member installs and leveling combinations in the near future on the forum.
View attachment 11057View attachment 11058
They did the Eibach 2.6 in front and 1.5 rear lift...wow that is high! Too high for my own taste, I prefer the stock height but leveled, the 1.6 Eibach or 1.5 Foutz is plenty IMO.
Agreed!
Leveled is perfect, in my opinion.
This very much reminds me of the old lifted Toyotas of the ‘80’s. I really like it!
But I love the pre runner look of it stock a little more. :)
Yea, same. I've begun the return process for the Pro Kit I ordered. I'm torn on what to do with lift and tires.
The eibach pro looks so damn good.. very tempting. May get a quote from my local shop for an install. 37s on an eibach pro is chefs kiss.
Have we established if a front level only will clear 37s with wheels that have a -18mm offset?
Update: sent request for quote on the full eibach lift from local shop and also just the front level springs. ill run 35s on the level springs and 37s if i go full lift.
They need to correct this asap
According to other YT channels the vast majority of RHOs are having problems...lets put a Poll to this Bulletpoint mount Power Running Boards - Mopar (82219228AB) - Mini Review BAJA LP4s New to the forum. YOLO: 4Runner to RHO
