Engine light no power
This is stupid easy to fix if you have the means to reach it. Home Depot sells e rings in their hardware section. If you can find the right size, it's a 60 second fix once you access it.
This will serve as a reminder for myself to grab spares and toss them into the glovebox just in case.
Ya that was a ten minute fix all better I don’t think it had a clip on from factory honestly
A E clip that stops the rod from coming off track if your valve stays open you get no boost build up which is what happen to me so I had zero psi and 3 engine lights all pointing to the turbo waste gate actuator and waste gate override or limit exceeded
Would you mind a series of pictures, from engine view to the exact point as above, to help others trace this down?
I can tomorrow if you look at the top right side of the engine you won’t miss it tho it’s the only actuator rod on top of a heat shield
I wonder is there was a clip there to begin with? I’ll look at mine tomorrow
Called it. Good work Rocko! Easy fix. Good idea to keep a spare in the glove box. It would not surprise me if one was missing to begin with.
What size clip did you end up going with?
RHO Delivered Unfortunately had to cancel my 26 order - too much craziness going on RAM RHO Behind the grille auxiliary light kit 👌 Who still does NOT have a scheduled date? Picking up L1 Canyon Lake @ MARK DODGE for $8K+ off MSRP
