Ram RHO Exhaust Testing | H-Pipe vs. H + Z-Pipe Combo – Which Sounds Better?
Dcchris311
RHO of the Month 🏆
Texas
2025 RHO
BMW X5 45e
USN
While trying to reduce exhaust drone, we ended up making a new muffler section as well.
Both setups are running our R.A.D. downpipes. The H-pipe setup has two 4" body mufflers, while the H + Z-pipe combo has none.
So far, we've managed to reduce majority of the drone below 2k RPM, making highway/city cruising much more enjoyable.
It's still a test section and needs some refinement, but I'm happy with how it's turning out.
Which one sounds better to you? Personally, why choose when you can have both?
I like the second one better. Both sound like diesels in the vids but I know how great your truck sounds in real life.
Would prefer to hear them under a load. Drive-by and acceleration. It doesn’t matter what it sounds like sitting in a parking lot, revving it.
Pictures?
Is the first sound clip the H pipe with the two 4 inch mufflers and the second sound clip the H pipe with the Z pipe? Or is it the other way around?
What is the rest of the exhaust system? Is it stock muffler? Is it somebody’s aftermarket?
I think both sound equally good. First one is more mellow but has that low rumble at idle. The second is more aggressive but being able to switch between the two at the touch of a button would be tops
Pictures?
Yeah, I'll be making some more video, driving, launching, etc. This video was made for someone who's been asking me to make a system that doesn't cost an arm and a leg just to get a slight sound improvement. Drone is dang near non-existent below 2k rpm. The truck is much more enjoyable now.
The first set of revs are H-pipe with 2- 4" mufflers. The second set of revs are H-pipe + Z-pipe. The rest of the exhaust is OEM.
This is my own system that I made and soon to be available. I still need to refine certain areas of it, I want to target a bit more of the drone range but thats a large frequency range.
No pictures will be shared as of right now.
At a touch of a button, you'll be able to go from HOA/Neighbor compliant to loud and rowdy.
Unavailable video
Same here, first one sounds much better to my ears.
I agree, the deep idle of the H-pipe sounds good but the Z-pipe on throttle sounds absolutely amazing!
If you dont want to divulge too much I understand, but:
1. Are you somehow using electronic valves to switch between the two setups?
2. With the h pipe muffler combo, how is cold start compared to stock?
Nice man , looking forward to hear driving vids at 2-2.2k rmps
What range do you encounter drone? Mine started at 1800rpm to about 2200rpm. I've significantly reduced drone from 2k down, slightly at 2100 and starts to pick back up at ~2200.
I'll hold off on question 1 for now. I'll release photos as orders ship out for it. A customer who has downpipes wants one asap.
This started off as a drone elimination/reduction part development. So that being said, I just used some "bullet" mufflers to test the setup. I'll making my own muffler now that the development was a success. But to answer your question with the current set up, it's very loud but it's a crisp loud and It doesn't have the humming sound. Thats because of the design.
Shoot, I didn't read your last question completely. I haven't been in a stock exhaust RHO since February 2025, so I don't remember what it soindes like. But as I mentioned in my previous, I'll be switching to a larger muffler to help with the cold starts. Moving to a HOA/Neighborhood friendly exhaust.
I was the first RHO with a Z-pipe, had it on for a couple months now. Also the first RHO with an electronic valved exhaust, had it completed for a few weeks. I’ll be posting some videos and details on Facebook groups tomorrow for anyone interested.
So it sounds like you had some custom fabrication work done? I love that tone at idle. Is this a beta for someone else perhaps?
I did it in steps to see what each item would change. I wanted to first install the z pipe, and to do it the way I wanted to retain all factory hangers and slip joints while keeping the stock exhaust I had to cut and weld the stock H pipe further upstream to create enough room to add the z pipe after it but before the stock slip joint. it’s essentially a factory exhaust still as far as the fit and finish and hanger/clamp locations just with a z pipe after the H pipe.
Keep an eye out for the post tomorrow, it should answer any and all questions about it.
2026 RAM RHO Order/Schedule/Build Thread What did you do to your RHO Today? Baja Design LP9 Bump kit I have a a scheduled date! What did you do to your RHO Today? My RHO has arrived!
