Go Rhino Sports Bar 2.0 w Power Actuator
@Phil Hergutz got mine installed today. question for you, is your cover locking and unlocking properly with the factory remote? If I lock the doors my cover can still be opened with the cover mounted buttons. If I hit lock twice the cover closes and unlock twice the cover opens as expected. Just trying to figure out the locking/unlocking details.
I haven’t had any issues other than I had to reset it one time as it wouldn’t work at all. To do that you hold the buttons on the TC down for 10
If anyone is looking to wire the 3 way switch to the in dash Aux ports, here is what I believe you will need to do. Keep in mind I have NOT verified this, but Steve from TRX forums was kind enough to provide this (he hasn’t done it yet either), but it really looks like it will work.
To anyone wanting to use the in dash Aux buttons this works! I wired it myself yesterday and now I can control the Go Rhino Power actuator to raise and lower the lights from the Aux switch. Special thanks to Steve in the TRX forums for helping me out! The guy is a top notch bloke! He didn’t know me from Adam and took my call and REALLY helped me. He had bench tested this solution but not installed it yet. I was the guinea pig for the install and it worked like a charm. This means you don’t have to use the 3 ways switch that comes with the Go Rhino light bar w/power actuator and can buy these cheap relays wide them up and use your in-dash aux switches!
Do you know if the EGR tonneau cover will work with the Mopar cargo divider? It has rails that are attached to the factory tie down rails that come with the BUG
Not sure, but with with the EGR cover you retain the factory tie down rails.
What's the total cost with lights?
I was 2800 for cover and 300 install. Didn't add any lights, the stock ones are fine for me.
How wide are the legs of the rhino 2.0 sports bar that bolt down to the side rails of the truck?
Fluid Leak - Please help me identify RAM RHO Mopar edition Marker Lights Ford to Ram New 2026 Order Traditional Gauges HELP!
