Hands free driving - lane change not hands free
varnerme
I don’t use this feature much, but had the chance today. Turn signals, whether bump or fully on did not cause a lane change. No vehicles were around. This used to work flawlessly. Anyone else notice this recently?
I did I turned my truck off and cleaned the front bumper sensors
We'd like to look into this for answers. Our team will follow up with you directly for this matter.
Chris,
Ram Cares
I use the feature regularly. It can be twitchy sometimes, especially if you initiate a lane change, interrupt it, then try it again, but for the most part, it's rock solid for me. As mentioned, be sure to keep your windshield & front bumper sensors clean.
I've never had an issue with lane changes, seems to work flawlessly. However on left hand curves it runs me completely off the road into the rumble strips and then yells at me to take control. I've read that they are going to introduce a level 3 system similar to Tesla starting in 2028 which I find terrifying. If they can't even get a system 2+ to work properly, how are they going to introduce level 3?
Works consistently for me. I have the HUD set up to show the ADAS stuff, and only hit the turn signal once I see the green line go from solid to dashed. It takes a few seconds after a vehicle has passed before it’ll go to the dashed line and allow assisted lane change. But it always works for me.
Did it show dotted green lines on ur hud? If the dotted green lines are there it will try to initate a turn. If they r solid green lines on the sides it wont.
Thank you for this helpful response! I don't recall if the lines were solid or dotted, but I will make it a point to look at that next time. What determines if these lines are solid or dotted? Road markings or painted lines on the road? I did try several times during the drive and it never worked.
No issues with lane changes but it will alarm and slam on the freaking brakes every time I go by a tractor trailer. :rolleyes:
The system in mine is useless except in a straight line. And not even then most times.
Road markers, lane size, cars next to you
If you’re in a HOV lane it also usually wont work because it’s not the standard size. If u can get the page where it shows the car and the green ADAS distance bars as the main screen it’ll show u if ur in hands free mode. Also should show if its gonna attempt to do the lane change
If its a orange arrow, its waiting for a space, Green with a x it canceled the change, then green means its going into that lane
Yeah, mine does it on right-hand curves, runs you into the passing lane, and then disengages. I know it can be fixed as hands on driving asssit is perfect and it is only hands free.
Been at the dealer several times for it and the last time the service rep was a bit annoyed (probably from lack of help on it from Stellantis since they really can't fix anything without running it by them).
Someone can fix this but I am sure Stellantis is blowing them off in sending someone to look at.
I've done maybe a few thousand miles in hands-free on the very busy I-35 between Dallas and Austin. No issues with traffic or lane management, blinker to change lanes occasionally does seem to not want to work, but overall I use the system without issues or concerns for long stretches on a busy interstate.
Exactly why I know it can be fixed. Many people have no issues with theirs.
Does your green lane guides show a dash line on one side ever? If you're in the right lane and the passing lane is clear the green lane guide will switch to a dash line on the left which means it will initiate the passing when the blinker is hit. Curious if yours does this and it still doesn't allow you to change lanes.
Hey Chris. Stellantis doesn’t give a f!€k. I appreciate your assistance but if they actually cared - they’d fix this.
Thank you for getting in contact with us. Using the VIN provided, we may have located STAR case S2623000024 related to your concern. Do know that we are looking into this for an optimal solution and your patience is appreciated as we continue to dive into this.
Chris,
Ram Cares
New Canyon Lake owner in STL...and a couple of quick questions Ram RHO Forged Blue Metallic Photo Thread Picked her up!! What did you do to your RHO Today? New member from South Florida All cleaned up.. Forged Blue
