Has anyone personally changed the rear diff fluid on their RHO?
RHOfan
Ram RHO
I was looking under the truck & there appears to be only 1 fluid access plug, located near the middle of the diff cover.
This leads me to conclude there are only two ways to drain the diff…crack open the cover…or, use a suction pump thru the fill hole.
Or, do I have the wrong diff? I recall watching a tech change the fluid on his TRX on YouTube. The TRX definitely had a drain plug near the bottom of the “pumpkin” and a fill plug at the top, behind some bracing. I thought RHO used the same diff as TRX?
I don't have a picture, but the drain is on the front of the diff, driver side. It is a 1/4" drive plug
even though it's a trx forum, this was helpful:
Found it! Lighting in my garage cast a dark shadow, so didn’t see it last night.
Thanks Gram10!
*** Post New RHO Photos Here *** Burger Tuning JB4 In Stock (+ Results) 2026 RAM RHO Order/Schedule/Build Thread What did you do to your RHO Today? RAM RHO HO Downpipes with High Flow Cats +100hp! Molten Red Photos
