Height
jared
If you have a tight garage double check your height! It looks like the RHO is a little taller than TRX and absolutely taller than a Raptor or lifted Jeep. I might need to cancel my order. I've got a garage door guy coming to see how much it will cost/if it's possible to squeeze out another inch without cutting. RHO is 81.9 inches baed on this https://www.motortrend.com/news/2025-ram-1500-rho-first-look-review/
Can anyone confirm the height?
I don't think anyone can confirm the height of the RHO yet. But if your 81.9" height is correct, then it's the same as a TRX (and I can't think of a good reason it would be any different). Just keep in mind that it might be a little taller if you have a Rambar. Come to think of it, is the Rambar even an option on the RHO?
Mine is 82.5" to the Rambar, which is just a hair taller than the sharkfin (which I measured at 81.75"). I had to adjust my garage door stops, so that it opened up as far as physically possible. The header over my garage opening is 83", so it fits...but just barely.
Wow, that's pretty tall! I'm assuming that if you put 37" tires, your TRX or a RHO will no longer be able to go in the garage.
Air the tires down good to go
Yeah, 37's are a no-go for me. And I can't put any lights on the Rambar either. It's not just because of my garage at home - I also regularly park downtown in garages with 7' clearances. I go real slow in them already (any bouncing, and I'd probably scrape the ceiling).
Mine actually fit into my garage, but with about an inch to spare with the fin on the top.
my garage has plenty of room up top but the truck is too long :/
This is an old thread, there are some new ones, including one I had pics in. 7' gives you about 2" to spare.
Battery is Dead in my RHO... JB4 or Diablosport.. that is THE question What did you do to your RHO Today? 2025+ RAM 1500 RHO / Rebel 23in Light Bar - PRO Installed Vossen HXF-6 18x9 zero Offset Traded my Level 0 RHO for Grand Cherokee Summit...
