Which wiring did you purchase? Can you send me the link? Thanks!This definitely works. With the Zautomotive Synapse it looks really good.
Love it!!!And we have light!
$15 and a bit of time, and we’re up and running!
Nice, just have to get the fender flare markers lit alsoAnd we have light!
Yeah the fuse jump trick on TRX did all the markersNice, just have to get the fender flare markers lit also
Wonder why it’s different with this wiring harnessYeah the fuse jump trick on TRX did all the markers
Hold up. Is there a known path to getting those connected to always on with ignition?Yeah the fuse jump trick on TRX did all the markers
Because you’re only grabbing the hood scoop lights and transferring it to an ignition source fuse. To get all of the clearance marker lights, you have to grab that white/green stripe wire at the source before it branches off to the rest of the clearance lights, like I outlined in this thread:Wonder why it’s different with this wiring harness
Wait does this work?Because you’re only grabbing the hood scoop lights and transferring it to an ignition source fuse. To get all of the clearance marker lights, you have to grab that white/green stripe wire at the source before it branches off to the rest of the clearance lights, like I outlined in this thread:
Marker Lights
Only a few zip ties holding the motor in right ? Yeah but they’re industrial strength zip ties. Bring your big-boy snips.www.ram-rho.com
It should. What this guy has you doing is cutting into the marker lights (kind of like a hack) at the point I have circled in blue in the pic below. If you want to get all of the clearance lights, you need to grab at the point circled in red. Rest of the instructions of what to do are in that linked thread.Wait does this work?
To my knowledge nobody has tried this yet, is that correct? Would be super cool if someone can be the guinea pig!I provided all of that info a year and a half ago in the thread I linked above:
Marker Lights
