Hyper milaging a RHO, Ha
Chubb McBoyle
2026 Ram RHO L1, SR, Serrano
Tesla Model Y performance, 6.2 Denali Ult Corsa AFE CAI
Kids and I went on a little jog for a killer burgers and shakes. 800 miles on the clock. 50 mile loop through the sticks, 1/3 of which was 100' hills and hollers. Averaged 54 mph. 53 there, 55 back. 20.2 mpg on the way there at 53, stopped once and easy acceleration at 2k rpms. On the way back, a neighbor i met wanted to hear me ring it out i hit 5 grand on tge way out of town 3 times and mpg dropped to 18.5. 55/56 all the way home and got home at 48 miles or so and 18.6 mpg. So far I am averaging 13 and AWE isnt helping matters. I got like short of 14 mpg at 80 mph on a 110 mile road trip to the StL and on the way home 14.6 mpg at 73 mph. Seems the RHO mpg is very sensitive to throttle input and speed. Milage drops like a box of hammers after 60. Pretty darn good at 55. This little experiment was just for poops and giggles and makes me feel better when im getting 11 mpg.
impressive I have noticed some pretty impressive even towing MPG numbers if I can tow at a steady 45-55mph. I got 15mpg towing on a 60 mile stretch our enclosed trailer.
Thats better than I would expect. So far im pretty impressed with the HHO. In the past 900 miles I have used 1/2 a quart of oil. I have done a number of full.throttle accelerations, i ussually feather into it so not from a standstill like the manual says. No biggie, thats normal.during break in. MPG is definitely improving.
How do you know this with no dipstick? Did you measure what drained out during an oil change? If so, that 1/2 quart was likely still in the engine.
I added half a quart from a 1 quart container. Each time I was one bar low, I added a quarter. I added yhe last quart at 900 miles and changed the oil the next day. I ahould have left it , but wanted to see if that would top it off again, it did. Leaving the filter on , I added 6 3/5 quarts. Again it showed one bar from full. I added oil leaving 6 Oz in the 7th quart and it shows full. I will be changing oil and filter between 2500 and 3000 miles. Then every 4 to 5k
Interesting. I just drain the oil hot and let it drip for an hour or two then add the 7.5 quarts they specify with a new oil filter at every change and call it a day. I don't trust the digital dash display. Mine is always at the last hash mark below the "max" red shaded area, but I think that is where it considers it overfilled.
I agree. Changed my oil and exact same thought process
Next oil change im elevating the front tires only and draining for at least 2 or 3 hours, prefilling the filter (40% of a quart from what I've read, tube going to itnis 10 to 20% of a quart) and putting 7.5 in ( including the filter) and ill see where this dumb ass digital sensor reads. When I got the truck it was one bar off but had 48 dealer miles and 4 hours of idle which is terrible for break in. Changing in 2000 miles or so
I have never read so much over analyzing of how to do a simple oil change that has been performed for over 100+ years WTF.🤪
I've never had a dipstick break, these digital dipstick are retarded
Let me help you out....drain the oil, remove filter, replace filter, add 7.5 quarts. Done. You're welcome.
Definitely dont need nor want your help.
I don’t get it either. I let it drain for 10 minutes while I deal with the filter. 7.5 quarts every time. Always at the 2 o’clock mark after doing the correct reset procedure. It’s really not difficult to do it correctly.
Isn't that amazing how that works. 🤣
But but but.....you've got to put the truck at a 22.675345 degree upward angle first, (but ONLY while we are in the autumnal equinox) and anoint the whole truck with Old Milwaukee's Best BEFORE you dare attempt to count the drops removed vs. put back. THAT is a proper oil change! Oh, and don't forget to just change the filter whenever you feel like it.
And let it drain for 2-3 hours. :LOL:
1000 comedians out of work. You guys are brutal, but I totally get it. Doesn’t take a YouTube video to figure it out.
INEXPENSIVE 6 Piston Brake Upgrade Is your RHO one of a kind?  Let's find out. With premium gas potentially hitting $8+/gallon by Summer, is anyone regretting buying a 14 mpg pseudo Baja truck?  No politics, please! RHO Haters Had em’ All! Show me your pie!
