Is your RHO one of a kind? Let's find out.
Winner of the most common RHO out there I bet! Thanks, thats a lot more than I would have guessed. Should have added the block heater, lol.
I see what you're doing. You're trying to play "Stump the Chump". Not gonna happen, man.
The most common RHO is this one. There are 290 of them.
Since I'm looking at "uniqueness", here's an interesting fact:
There are 1,204 one-of-a-kind RHO's. So 17.77% of all the 2025 RHO's that were stickered in USA/Canada are unique.
Now, here's where it gets mind-blowing. There are only 2,046 combinations of options that were actually built (out of 172,032 possible combinations).
Even more mind-blowing? Since there are 1,204 unique combinations out of the 2,046 combinations built, that means it's more common to be one-of-a-kind. At least from a combination standpoint. But the actual number of "more than one built" trucks is higher than "one-of-a-kind" trucks.
Ok, I'm done now. I don't think that made much sense to anyone but me
There are liars, damn liars, and then there are statisticians 😂
Yours is 1 of 5 (edited from 1 of 6).
There may be a flaw in your data. I found this truck at a dealership because my first order got damaged. The second one got canceled by ram so I located my truck and they had three of them on the lot. Of the 6 you show 474, 475 and 476 on that lot. 474 does not have bedside graphics so that’s what tells me your data may be flawed. I’m positive it wasn’t ever on the truck because 474 is the one I was going to buy because I did not want the graphics, but unfortunately, it had a big scratch in the driver‘s door jam. Bedside graphics was not on the window sticker. It was the cheapest of the three trucks
Interesting. I just checked that window sticker (696474), and you're right. Somehow it populated for that search, so I'll have to figure out what happened.
So I learned something today. The Windows search function doesn't work correctly unless you've "indexed" the folder for searches. I believe this is a bug, because it should return correct results. Either way, there were indeed a few discrepancies after I indexed the folder and re-searched all the results. Now I'll have to go back and see if it changes anyone else's results.
I've edited your results (above), and made it light blue to signify that the results are corrected (which I guess I'll have to do for everyone, just for posterity).
In the meantime, if anyone has noticed, the total number of stickered RHOs is now up to 6,778. I found a few new window stickers over the past 24 hours. And I suspect a few more will appear. All of these new ones look to be "Mopar Package" trucks...so it looks like there was a hold-up on getting some of these out of the factory. Could have been a shortage of the tool kits, or Rambars, or something else.
Thanks for finding that discrepancy, by the way.
Now that MY25 is complete, I have compiled the window sticker data. So it's now possible to analyze your specific build against the others. I've done this same thing on the TRX forum ( https://www.ram-trx.com/threads/is-your-trx-one-of-a-kind-lets-find-out.18218/ ) for all model years. Unfortunately, Stellantis took the build sheets offline starting with MY25, so the data has to come from window stickers. Since these are only published for USA and Canada, I don't have access to any data for export models. Or any trucks that were built but not stickered (such as pilot vehicles). So it's not a perfect analysis, but probably the best we're going to get.
I'll kick this off with an example that I did on another thread, and go from there. If you'd like to see the results for your truck, post up the VIN and I'll run it for yours.
@RamFan's truck is one of a kind. The chart below can be read as follows:
For 2025, there were 6,776 RHO's built. Of those, 1,204 were Bright White. Of those, 959 were Level 1. Of those, 755 had the Pano sunroof. And so on. If you get to the end and there's only 1 truck left, then yours is one of a kind.
So mine has the beadlocks…maybe in the folder it got misplaced? :)
Either way…the work you’re doing, GOLDEN!!
Thank you 😊
A wise man once said….
manipulating Pivot tables isn't for everyone…😉
Thank you 😊
Man, you f-ed me up. I actually went back and checked to see if there was a mistake. Then came back and saw your little smiley face...
So I just got done redoing all the results. There were three changes (all for the better):
  • @scappellino - your results went to 1 of 7 (from 1 of 10)
  • @rtfd333 - your results went to 1 of 2 (from 1 of 3)
  • @kaos_859 - your results went to 1 of 6 (from 1 of 7)
Hopefully there are no more changes to existing results (other than new window stickers popping up).
No I was being friendly nice respectful etc. 😊.
I DO have beadlocks and your breakdown shows standard wheels.
Sorry to be the bad news guy. :(
JANUARY order updates! Tire pressure Trade Ins Wheel & Tire Bundles, Maybe more affordable now? 2027 RAM RHO Order/Schedule/Build Thread Reflective concepts decal
