M&R Light Bar Install Question
Sorry I screwed up my quote
I was asking about the Diode Dynamics @jbrans3 mentioned.
They have various options as well for beam pattern and output.
To be fair, I do not have huge forearms, and even then it was uncomfortable… but it was a really quick install job. I also wasn’t going to purchase a light bar if it meant tearing the front end apart.
I have to say, this light bar seems to be around 3-4x brighter than my HI beams. Truly impressive output for such a small light kit.
So, I didn’t have to do this? Huh.
I picked up a M&R Pro Light Bar a couple of weeks ago and just got around to install this past weekend. For those of you that have installed one, I have a quick question.
The install instructions said to adjust the brackets so the light was tilted fully downwards. I did this initially, but had difficulty with alignment when I tried to marry the brackets up to the grill. I ended up removing the downward tilt to the brackets and instead mounted it pretty much straight forward. That seemed to help with installation, but made me curious if my light bar points up higher than others after doing so.
Also, I noticed my bar can either sit on top of the bumper, or fall behind it. I think the intent is to sit on top of the bumper, but it would certainly be easier to adjust the tilt downward if it were behind the bumper. Curious how you all installed. I put pictures of the two options below.
I noticed also that my brackets appeared a bit different design than those in the video. Maybe that’s contributing to my issues?
Also, note that you can adjust the Allen head screws even after install if using a stubby Allen wrench. The video says this can’t be done, but it can. I find that the bar is wedged in pretty tight, though, so I can’t really adjust the tilt if it’s sitting atop the bumper.
Also, I installed without removing the grill. Definitely put a towel or something in between your arm and the plastic, or it’s pretty rough on your skin. Otherwise, this made for a really simple install. I’m very pleased with the brightness of this light bar!
Same thing happened to me. I ended up removing the grille and moved it up higher. It's not that hard and worth getting it right.
Exactly! It’s not like we’re stupid. Right? Oh…
Just to clarify, Due to the angle of the grille and the mounting brackets, the light should be angled so that its facting parallel to the ground. Believe it it wants to be angled upwards normally. Thats why we recommend adjusting.
What kind of shop will do this work? I tried it without removing the grille and my arm is not even close to fitting. I'm not the guy who's gonna remove the grille himself.
Seems the mechanics and body shops around me don't want this work. Would a dealer do it?
Did you remove the hood latch? It was tight for my arm as well. You could loosen the upper portion of the grille so you have some give up top.
I sure did. I even reinstalled it slightly too low and had to remove all the trim and do it again once my hood wouldn't latch lol.
Haha... Shit happens... Now you know. AllnI can suggest is to undo the upper portion of the grill to give you some more room without the rest of the bullshit. If you were in the detroit area id gladly give you an arm...
I love and miss Detroit!
My arms were too big too. I had to have my daughter come out and help me but I got it done!
Said no one ever...
LIES!!! :)
It’s a cool town and is having a renaissance of its own. I lived in Farmington Hills..and love Michigan. And their BBQ..I’d say is at least if not better than Texas.
LIES!!! :)
Ok 8 Mile...
I only bought an RHO so I dont have to worry about all the potholes in South Eastern Michigan... But im not sure any of this solved Matts problem. And also I dont think I have small arms, but now I have a complex. Off to the gym now...
My dealer did
JB4 mounting options What did you do to your RHO Today? Picking up from Mark Dodge RHO Bed/Tonneau Covers L1 Canyon Lake @ MARK DODGE for $8K+ off MSRP Living with the JB4
