If they are 7" wide they should fit. Triple-R's pictured below are 7" wide and they go in no problemo.
Im thinking I may have installed the brackets too far inward which is why only the TRX holes are working.If they are 7" wide they should fit. Triple-R's pictured below are 7" wide and they go in no problemo.
Is it possible to just purchase the mounts still? Or is it only the kit?![]()
PSP RAM TRX / RHO behind the grille aux light kit
RAM TRX / RHO 64oz fabricated aluminum and tig welded washer fluid tank with auxiliary light mounts. Features: 3D scanned and CAD designed for OE like fitment Allows up to a 7โ light to be mountedโฆpinnaclespecialtyperformance.com
Tank $444.99
Mounts $198.99
RAM TRX / RHO 64oz fabricated and tig welded washer fluid tank with auxiliary light mounts.
Allows up to a 7โ light to be mounted behind the grill. Max height of 7.4โ.
The washer tank mounts in the oe location and uses the oe pump, sensors, seals and filler cap.
Mounts are laser cut and tig welded also and bolt to the radiator support using oe hardware. Super rigid design with no deflection.
Kit onlyIs it possible to just purchase the mounts still? Or is it only the kit?
yessir! I have kits built and ready to ship.@DBallz
Is the kit still available? Looking for a nice pair of lights to go with it as well and saw youre a distributor.
I just need to get better with my tig welder. Wonder if they would sell you the precut aluminum and steel. It would probably save you several hundred dollars.![]()
Tank $444.99
Mounts $198.99
4-6 weeks depending on laser and powder coat. You can back order if you like.@DBallz Any idea when you will have stock back for the tank and light brackets?
4-6 weeks depending on laser and powder coat. You can back order if you like.when will the kit be back in stock?
@DBallz what kind of lights are being shown in the above picture on the blue RHO?Haven't played with the high beam as a trigger yet. If it is CANBUS Triple-R makes an interface https://www.triple-r-lights.com/canny-can-interface-direct-cont.html
I have used the oe high beam as a trigger on the ol' ladies jeep and the factory fog light as another trigger for some nacho quatro's and it is super slick. Top led's come on with high beam and the bottoms come on with fog light switch.View attachment 17997
I have used a wire tap on the harness coming off of the hood marker lights on the passenger side with success for the DRL function. That way whenever the factory running lights are on so are the aux light DRL's, no switch required. Then you could use aux 1 switch for your high's on the LP6's and 2 for the lows.
Triple R Sentinel.@DBallz what kind of lights are being shown in the above picture on the blue RHO?
