Recommendations on undercoating, rustproofing
nvcnvc
2027 Ram RHO
2023 JEEP Gladiator Rubicon
What do you all use, if any? I recently moved to Cape Cod, Mass and even though the the of salt on the roads is not as frequent as it is in Boston area, there is some. I have a local guy that does Line X but I thought I ask you all what do you recommend for rustproofing. Due to my current housing circumstances the track will be outside for the winter of 2027. I would like to protect it as much as possible. Thanks
This is what I use and where I go.
Wool wax and Fluid Film are the 2 main products to use for this. I used fluid film when I lived in Alaska on my old truck. Works very well it creeps better into cracks and cervices than the Wool wax but it's not as durable and needs reapplication pretty much every year. Wool wax is thicker and longer lasting but doesn't creep as well. They both come in black colors, so it looks good on the underside of the truck. You don't want to use any kind of bedliner type material because if water/salt gets under that type of coating it will hold it up against the body and cause rust. Wool wax and Fluid film are both self-healing in that they don't fully harden and they continue to creep along the body to fill in spots. only downside to them is when working on the truck you will get it on your clothes and hands it's a bit messy in that regard. You can apply both of them yourself with an air compressor and the sprayers they sell. I sprayed fluid film through a cheap battery-operated airless sprayer. you can touch up areas you may miss or need a little application with a paint brush. Worked great and you don't have to drag an electric cord or air hose around with you under the truck. If i had to do it all over again i would choose Wool Wax based on it being more solid and longer lasting.
RHO Mud Flaps Upsized from 18s to 20x10s et -18 TRX grille letters What did you do to your RHO Today? Just ordered - anyone have the 2026 Blue color with pics? Ram RHO Forged Blue Metallic Photo Thread
