- Oct 11, 2025
- 123
- Media
- 64
- 346
- 2006 dodge ram 1500
- Current Ride #2
- 2007 Subaru WRX StI
This should help.What's the difference between the RB30 and the RB20?
Do the brackets hang low under the rail connections and reduce ground clearance by very much, it looks from the pictures online it’s possible for the brackets to get caught on stuff? I noticed the mopar ones have more of a flush bracket connection to the rails, lessening the ground clearance issue. Haven’t seen many picture of the RB’s from the underside installed, can you confirm?
Do you have any pics of them installed? I'm considering the same.I have these and they work well. I ordered Amps before I even had the truck and got tired of waiting after the lift/37s. My only gripe is that they had a chip in the board on each side that required some black paint to cover.
I cannot recommend the Go Rhino ones. The magnets were a constant issue and an eyesore.Go Rhino uses magnets and doesn't plug into your odb port. I like that option. For whatever that's worth as well. Lol.
I actually went with the Westin power steps. It uses the magent system as well. 1.5 years in, no issues. Knock in wood.I cannot recommend the Go Rhino ones. The magnets were a constant issue and an eyesore.
